I guess as near as it is so far...
I second that.
After I redo the thermo paste of my desktop machine, the idle temperature dropped from 46 to 30.
Oh un autre français!
Anyway thanks everyone, it's really nice to see such a good community!
Hi guys, after several trials and errors I found the solution!
First I reinstalled zorin 16 pro but this time by selecting modern nvidia graphics (note that there was an error but it still worked).
Second when I tried to boot everything seemed to work fine except a tiny bit of lag and the screen which was stuck in low resolution (640x480, so 4:3).
Third I did this (saw it here: drivers - Stuck at 640x480 resolution; - Ask Ubuntu)
- Search Nvidia packages
$ dpkg -l | grep -i nvidia
- Remove all the Nvidia drivers
$ sudo apt-get remove --purge '^nvidia-.*'
- Go to: Software Updatesâ˘Additional Driversâ˘select first oneâ˘Apply Changesâ˘reboot
It didn't work when I tried to apply changes at first, so I selected and re-applied the changes again and this time it worked for some reason...
After the reboot absolutely NO lag, my laptop is really fast and average temp of cpu is 60°C. Everything ends well!
Thank you so much for those who helped me, and I hope this will help someone with the same problem!!!
