I've.. Got many problems I'm trying to tackle being new to Linux (Roughly <24 hours experience yet.. lol) but I suppose I should keep this to one topic? -- Audio filtering. It seems Zorin does not natively support this and I did forget that my mic basically needs echo cancellation and noise cancellation, otherwise it sounds like hot garbage. (Something Realtek took care of in Windows 10.) Now I hear Easy Effects is the way to go. Well, I did allot of work to try and get that installed, using mostly the terminal, until I realised the app store (thing) had Easy Effects right there; so now I have that successfully installed, but it's not picking up any app or devices, even though Zorin has the devices showing perfectly. So, I'm wondering if (and I very much imagine) I screwed it up somewhere between the excessive install attempts, library attempts, and, yes, GPT. (I'll post a link but, I'm sorry, it's lots and LOTS of logs because it's mixed with other stuff too.)
So, Easy Effects wasn't the first thing I tried (new to Linux) and neither was it with GPT. (But if there's another audio filtering engine then sure I'll use that. Whichever works!) While my day (this week) has been very busy leaving me barely time to get to everything, roughly my process with Easy Effects today has been along the lines of asking Chat-GPT for links to download from the apt page / github and similar, because I'm not yet familiar with how to just search packages and install on my own yet. (The horror, I know.) There were a few times I looked up something on Google but, sorry, I defaulted back to GPT. A few of the libraries I had to find alternate ways to download and install and also had problems installing them, so I can very much imagine yet more problems caused simply from that. At any rate, the most trouble I had I think was EasyEffects -> rnnoise -> libsigc++-3 -> libsigc++-3.0.7, each having to have their own dependency, download, remove folder, reinstall, etc. process. In the end, I think trying to install EasyEffects via terminal had me stop at not being able to find desktop file util, libportal-gtk4-dev, and EasyEffect itself outputting some error at line 838 of plugins_box.cpp from easyeffect's ./src/ file. I did not remove any of these files or directories when I later discovered Easy Effect's app page and found it to just work there.
GPT log: https://chat.openai.com/share/96537f52-a5ee-447b-bd25-d2bf4e02334c The start is related to random topics in Gamemaker Studio and AIDungeon or other similar things, and only when I start with Linux and GPT starts at 5% of the way in and further. (Way more than I thought.) I believe it goes itch.io -> ADoM -> and the rest of the 94% ish is Easy Effects. (Sorry, to anyone/everyone who reads it all.)
I believe I'm on Zorin 17.1 core 64-bit, "windowing system" X11; I have a MSI MAG H410 Infinite_MS-B915 motherboard, 32 GB RAM, Intel Core i5-10400F CPU, and NVIDIA GeForce GTX 1650 SUPER for my GPU. The current version I have is 550.54.13 (Proprietary thing) CUDA Version 12.4. (If I'm missing something, please let me know and, being new, how?? Sorry.) The packages I've manually installed/modified (Thanks in part a command line I found online and GPT helping me to modify it for legibility) details this:
Installed packages:
apt install: libsdl2-image-2.0-0
libc6
libjpeg8
libpng16-16
libsdl2-2.0-0
libtiff6
libwebp7
apt install: libluajit-5.1-2
libluajit-5.1-common
libc6
libgcc-s1
apt install: libsdl2-mixer-2.0-0
libc6
libflac12
libfluidsynth3
libmodplug1
libmpg123-0
libopusfile0
libsdl2-2.0-0
libvorbisfile3
apt install: libsdl2-net-2.0-0
libc6
libsdl2-2.0-0
apt install: libncurses5
libtinfo5
libc6
apt install: libsdl2-ttf-2.0-0
libc6
libfreetype6
libharfbuzz0b
libsdl2-2.0-0
apt install: libsndio7.0
libasound2
libbsd0
libc6
apt remove: libsndio7.0
apt install: libsndio6.1
libasound2
libbsd0
libc6
apt install: libwebp6
libc6
apt install: libfluidsynth1
libasound2
libc6
libglib2.0-0
| libjack-jackd2-0
<libjack-0.125>
libpulse0
libreadline7
libsndfile1
apt install: libmad0
libc6
apt install: xbindkeys
guile-3.0-libs
libc6
libx11-6
apt install: openrazer-meta
openrazer-driver-dkms
openrazer-daemon
python3-openrazer
apt install: debhelper dh-python linux-headers-generic python3-setuptools lsb-release dkms
E: No packages found
apt remove: xbindkeys
apt purge: xbindkeys
apt install: git
libc6
libcurl3-gnutls
libexpat1
libpcre2-8-0
zlib1g
perl
liberror-perl
git-man
git-man
apt install: meson
<python3:any>
ninja-build
python3-pkg-resources
python3-setuptools
apt install: build-essential
| libc6-dev
<libc-dev>
gcc
g++
make
dpkg-dev
apt install: libglib2.0-dev
libffi-dev
libglib2.0-0
libglib2.0-bin
libglib2.0-dev-bin
libmount-dev
libpcre2-dev
libselinux1-dev
pkg-config
zlib1g-dev
apt install: itstool
python3
python3-libxml2
apt install: ladspa-sdk
libc6
libsndfile1
libstdc++6
apt install: libzita-convolver-dev
libfftw3-dev
libzita-convolver4
apt install: cmake libtbb-dev
apt install: libpipewire-0.3-dev
libpipewire-0.3-0
libspa-0.2-dev
apt install: libgtk-4-dev
gir1.2-gtk-4.0
libcairo2-dev
libegl1-mesa-dev
libepoxy-dev
libfontconfig-dev
libgdk-pixbuf-2.0-dev
libglib2.0-dev
libgraphene-1.0-dev
libpango1.0-dev
libwayland-dev
libx11-dev
libxcomposite-dev
libxcursor-dev
libxdamage-dev
libxext-dev
libxfixes-dev
libxi-dev
libxinerama-dev
libxkbcommon-dev
libxrandr-dev
libvulkan-dev
pkg-config
wayland-protocols
libgtk-4-common
libgtk-4-1
apt install: libadwaita-1-dev
gir1.2-adw-1
libadwaita-1-0
libgtk-4-dev
apt install: mm-common
| automake
<automaken>
libtool
pkg-config
apt install: docbook-xsl
xml-core
apt install: liblilv-dev
liblilv-0-0
libserd-dev
libsord-dev
libsratom-dev
lv2-dev
apt install: libbs2b-dev
libbs2b0
apt install: libsndfile1-dev
libflac-dev
libmpg123-dev
libopus-dev
libsndfile1
libvorbis-dev
libc6
libgcc-s1
libstdc++6
apt install: libebur128-dev
libebur128-1
apt install: libsamplerate0-dev
libsamplerate0
pkg-config
apt install: libsoundtouch-dev
libsoundtouch1
apt install: libspeexdsp-dev
libspeexdsp1
apt install: nlohmann-json3-dev
apt install: libfmt-dev
libfmt9
apt install: libgsl-dev
libgsl27
libgslcblas0
apt install: libportal-gtk4-dev
gir1.2-xdpgtk4-1.0
libglib2.0-dev
libgtk-4-dev
libportal-dev
libportal-gtk4-1
pkg-config
[Removed irrelevant help topics. Sorry for that, weird "don't spam" mindset.]
