No Bluetooth Found (Realtek?)
https://www.pcmag.com/how-to/how-to-run-windows-10-from-a-usb-drive
Under Control Panel > Power Options you should be able to find Fast Boot or Fast Startup setting.
https://answers.microsoft.com/en-us/windows/forum/all/turn-off-fast-startup/5362cd29-86ca-4b39-be60-718446f9d5f8
Or
Secure Boot is a BIOS setting, not a Windows setting.
You can access BIOS Settings in the normal fashion based on your manufacturer, usually F2 or F10.... when you see the motherboard splash screen. Move to the Security Tab and look for the Secure Boot option.
thanks but I know how to do that from windows I meant from linux zorin
The steps are nearly the same. Download the Windows OS .iso file - then burn as a bootable usb stick using an etcher like Unetbootin, BalenaEtcher, Ventory or another preferred etcher.
I have balenaEtcher
and I know how to use it now I have strange problem
1st I can't download the Windows 10 home ISO
2nd I already burn Zorin Core on my flash disk and now the flash disk is read only and I cant format or do anything :man_facepalming:t4:
It helps to have many USB sticks handy. :wink:
Ah... I cannot comment on this as that is a Microsoft issue. Maybe try at a different time or try using a different server...
If you have another Windows machine, you can use that machine and the Media Creator tool - makes a Win USB installer. But, has to be in Windows.. (Win10/11 creator tools last in list)
Just a heads up - the .ISO downloads don't come with SSD / NVMe drivers (RST-F6Floppy-19.5.1.1040); you'll likely have to add them to the installer after writing (USB).
Are you using VPN?
I don't quite understand the picture :thinking:
No VPN and this message says that I can't download because Microsoft services banned from my location
Although I see no solutions and I see off-topic posts muddling the issue, this thread demonstrates that this can be caused by s simple server error:
https://answers.microsoft.com/en-us/insider/forum/all/i-can-not-download-windows-11-due-to-a-error/6fc27a1c-e3f6-4367-8abb-11143d63d70d
maybe :man_shrugging:t4:
Now I have access to this menu
but when I try startup repair it's not working and I have no access for the windows
Which edition of Windows OS is this?
Windows 10, I know, requires EFI boot.
yeah exactly windows 10 home
Zorin OS would not change Windows Boot...
Something else is going on here. May be a disk corruption (minor). Hard to say.
I would really just go about either installing a different OS on the drive or reinstalling Windows OS at this point.
From a Win installer, you can use the Command Prompt and issue:
bootrec /fixboot or bootrec /fixmbr - then would also do bootrec /scanos and bootrec /rebuildbcd
After running those reboot, and that should fix the Win boot issues; given there are no errors.. This can be done with any Windows install disc btw, Win7 and newer.
Or, run the 'Startup Repair' utility to see if it finds any issues - and if so that can help automate the process.
this didn't help got error can't help
I tried some of it and I got another error I'll try to get pics for it today
@PlumpKibbles here we go that's what I got
last update in my case:
I was searching and found this I used sudo modprobe btusb
then sudo systemctl start bluetooth.service
then checked the statues using this $ sudo systemctl status bluetooth.service
and I got this now
but still when I'm trying to use it nothing happen
still no bluetooth found
after I rebooted my laptop I found it again inactive(dead) and needed to type
to make it active again
You have to specify with changing to the C drive, or adding C:\ at the end to check the C drive, where your Windows install is located. Your installer is good now though! :+1:
But, some of your older pics indicate that maybe the Windows partition was renamed, or name removed - which would cause some issues when trying to find your Windows install..
You could try again with using the C:\ path indicator - if that doesn't work, I'd say you probably need to just reinstall at this point..
