I won't deny I am worried about your case. You have tried a lot, already. I'm not the giving up type, though.
Did you see above about sof-firmware? Had you tried that yet?
It seems that I can't save the grub changes? I checked and when I rebooted it was back to "quiet splash"
also I am editing Grub_CMDLINE_LINUX_DEFAULT="
not GRUB_CMDLINE_LINUX="
GNU nano 4.8 /etc/default/grub Modified
If you change this file, run 'update-grub' afterwards to update
/boot/grub/grub.cfg.
For full documentation of the options in this file, see:
info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=lsb_release -i -s 2> /dev/null || echo Debian
GRUB_CMDLINE_LINUX_DEFAULT="snd-intel-dspcfg.dsp_driver=1"
GRUB_CMDLINE_LINUX=""
Uncomment to enable BadRAM filtering, modify to suit your needs
This works with Linux (no patch required) and with any kernel that obtains
the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
Can you please (again)
sudo update-grub
then
sudo nano /etc/default/grub
and looking to ensure it looks the same as above- then reboot and check if grub has reverted.
Sure give me a minute
Okay I was able to save the changes after reboot but still no sound.
As much as it stings, can you please revert grub back to just "quiet splash" - it is best to always revert a change that does not work.
Then update grub.
Ok - sof-firmware- I think that is where we left off before... had you tried that (Or did I miss a post?)
I got an error when typing the command sof-firmware. Do I need to install sof-firmware?
No problem about reverting
That answers my question:D
It is not in the Main Universe repository but is indendently developed. I do not know if this will work for you on your machine. It has helped many though and it is why I love Linux- Many indie devs out there see a problem and independently create a solution- rather than relying ont he MS pipeline.
As ignorant as I am I don't know how to install SOF? Do I need to enable a repository? Do I need to download a kernel? Thanks for all of your help!
Don't worry. Part of what is taking me so long is me reading the documentation to learn how to do it, too ![]()
Tech, can you do me a favor...
sudo apt install synaptic
Once installed, open it (enter pw) then on the top toolbar, click Search
Enter in linux-headers
It will be a lot of scrolling... But please look for the Highest mainline signed kernel available.
Might look like:
"linux-headers-5-.13.0-10100oem"
Sure. hold on
Okay I see the "linux-headers-5-.13.0-10100oem" but it is not highlighted or it doesn't have the box filled in so I think it is not installed
To install sof-firmware:
git clone -b stable-v1.6 GitHub - thesofproject/sof-bin: Firmware and topology binaries
cd sof-bin
sudo ./go.sh
Reboot to test...
Ok, it wouldn't be installed, but I wanted to know what was available to you.
I tried to install sof-firmware and tried instructions on link but I do not know what I am doing?
Do I just enter the commands in the terminal?
Yes. Open terminal and then just copy and paste each line in as posted above.
git clone is the program being used to get the package. If needed, you can install git with sudo apt install git
cd command is Change Directory
.sh is the Installer script.
