I installed git. I pasted the commands in terminal and got errors.
git clone -b stable-v1.6
fatal: You must specify a repository to clone.
usage: git clone [] [--] []
-v, --verbose be more verbose
-q, --quiet be more quiet
--progress force progress reporting
-n, --no-checkout don't create a checkout
--bare create a bare repository
--mirror create a mirror repository (implies bare)
-l, --local to clone from a local repository
--no-hardlinks don't use local hardlinks, always copy
-s, --shared setup as shared repository
--recursive ... alias of --recurse-submodules
--recurse-submodules[=<pathspec>]
initialize submodules in the clone
-j, --jobs <n> number of submodules cloned in parallel
--template <template-directory>
directory from which templates will be used
--reference <repo> reference repository
--reference-if-able <repo>
--dissociate use --reference only while cloning
-o, --origin <name> use <name> instead of 'origin' to track upstream
-b, --branch <branch>
checkout <branch> instead of the remote's HEAD
-u, --upload-pack <path>
path to git-upload-pack on the remote
--depth <depth> create a shallow clone of that depth
--shallow-since <time>
create a shallow clone since a specific time
--shallow-exclude <revision>
deepen history of shallow clone, excluding rev
--single-branch clone only one branch, HEAD or --branch
--no-tags don't clone any tags, and make later fetches not to follow them
--shallow-submodules any cloned submodules will be shallow
--separate-git-dir <gitdir>
separate git dir from working tree
-c, --config <key=value>
set config inside the new repository
--server-option <server-specific>
option to transmit
-4, --ipv4 use IPv4 addresses only
-6, --ipv6 use IPv6 addresses only
--filter <args> object filtering
--remote-submodules any cloned submodules will use their remote-tracking branch
--sparse initialize sparse-checkout file to include only files at root
