I have recently installed Zorin OS 16 on my Mac Mini 2018 (v8,1).
Apart from the slow start-up (not critical) and audio output (important), everything work fine.
My USB headphone works well but not my speakers connected to the jack port.
When I look on the list of audio output devices, I can't see the jack. I have tried to use pavucontrol but same problem.
Here is some information from my system:
> lspci | grep -i audio
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
02:00.3 Multimedia audio controller: Apple Inc. Apple Audio Device (rev 01)
> cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x81e10000 irq 90
1 [S5 ]: USB-Audio - SteelSeries Arctis 5
SteelSeries SteelSeries Arctis 5 at usb-0000:00:14.0-5.1, full speed
2 [Camera ]: USB-Audio - Aukey-PC-LM1E Camera
Aukey-PC-LM1E Camera Aukey-PC-LM1E Camera at usb-0000:00:14.0-5.2, high speed
OK. Lets give it a try.
In terminal, type alsamixer
Hit [F6] and check it has your sound card selected.
Then display "All" sound channels and post a screenshot here.
If this is your first time on that site, it will have a notification up at the top of the page that is asking you to install the Gnome Browser integration, please click the install link to install it.
Then, at the link I provided above, you will then see a toggle button show up on the right side of the page.
Please click the toggle button to install the extension, a popup will come up asking you to confirm, by all means, do confirm it.
Now your extension is installed, and it can be found on the right side of your taskbar.
It is Amazon's trick to place negative reviews in a less obvious place
I hope you will find SoundBlaster works better for your mac.
Funny, it says compatible with Windows 7 and 8. Nothing mentioned for Linux. But in reality, I've never seen an external DAC which is incompatible with Linux.
Whenever I shop for hardware for Linux, I try to put Linux in the search. The greatest compatibility, will always be those that state Linux is the title or description.
It depends. For USB DAC. I do no bother.
It is Windows which requires additional driver but not Linux. It is integrated in kernel.
Actually I found some claims for "Linux compatible" are not very trustworthy. I am sure UGreen is more reliable than other brand-less products. But the performance is another question which is what Salamafet experienced.
Luckily at French Amazon, there is a selection for return reason for "poor performance".
