No startup sound -Output device is correct and working
Is there an enable / disable switch for the startup sound?
New 18.1 pro install and I now get no startup sound.
The output device is correct and working.
Sounds at /usr/share/sounds/zorin/stereo play fine if I open each one from FILES.
Thanks all.
Hi, have you looked in 'Startup Applications'? This is where the login sound resides. Works in live (Try Zorin) mode but gets disabled post install.
Follow the one for 24.04
