After I installed the new Zorin update I lost my wifi adapter again. I checked my first solution that I used when I first installed zorin but it didn't work. Why did I lose my adapter;
It's possible that a newer kernel (5.11-43) has made a regression for you. Can you post a output of lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166a
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166b
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166c
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166d
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166e
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166f
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1670
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1671
01:00.0 3D controller: NVIDIA Corporation Device 1f9d (rev a1)
02:00.0 SD Host controller: O2 Micro, Inc. SD/MMC Card Reader Controller (rev 01)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device 8852
04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Device 1638 (rev c5)
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
And lsusb
too please
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 04f2:b6be Chicony Electronics Co., Ltd Integrated Camera
Bus 003 Device 003: ID 0bda:4852 Realtek Semiconductor Corp. Bluetooth Radio
Bus 003 Device 002: ID 2357:0602 TP-Link USB 10/100 LAN
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Interesting, i only see LAN.
Reboot and enter GRUB, change the kernel to an older one
uefi - press the escape key alot during boot
Legacy bios - press the shift key alot during boot
A general question, if I have dual boot as long as I update the drivers from one of the two operating systems , do they both read them? what I'm thinking is that not as long as they have two different storage spaces for each operating system.
Each os reads its own driver, if you update the driver in windows it is only readable in Windows. For linux it is the same.
Try the .40 one, if that does not work the .38
.40 (recovery mode) or .40-generic?
Just generic
What the difference?
Worked!! Thank you.
But every time I update my system do I have to do that? Also on the next reboot this remains or every time should I choose it
No idea never done this before my self. If the newer kernel kicks in again we can delete it. Download synaptic from the store and search for kernel headers (5.11.0-43)
I downloaded the program, how do I find the right file in this mess?
Search for linux-headers or 5.11.0-43 and take a screenshot of it
Okay, just delete the first?
Full screen image would be better
I am not behind my laptop...open terminal
sudo apt-get purge linux-image-5.11.0-43-generic
sudo apt-get purge linux-headers-5.11.0-43-generic
That should remove the newer kernel verion.
