Will that work if I installed Zorin Lite “in place of” windows (yep- wiped hard drive…) I didn’t find ANY drivers available. [msg states: Unable to download firmware updates…Cannot resolve hostname].
TechNut, can you provide a bit of history and details that can help us to approach this question?
What hardware are you running? What symptoms are you having in wifi failing to work?
The message
suggests that the repo for your firmware updates is giving a 404 error.
From the side:
Intel Pentium Processor E2210
NVIDIA GeForce 7050 Integrated
320 GB HDD
3GB DDR2 Memory
A cpu (emachine) purchased new '09. It always seemed ‘screwy’ since a younger person took control of it before I had access. Of late I’ve tired of microsoft, windows; started exploring options. Watched videos, finally took the plunge. I realized that installing Zorin “in place of” windows (not alongside) had some risk, but didn’t think that I’d have no internet access initially.
Contacting the Help peeps, they said to run the command: sudo lshw -C network > wireless.txt
[At 1st I thought the ‘l’ was ‘I’ but no matter how I ran it got no joy on that. Trying different ways of entering command, I got this other reply: “You should run this as a super-user”. Can’t think of any more ‘super’ user than myself…
[I am a rookie - willing to learn, invest time, etc. but in the meantime I’m counting on the highly-touted support commuity].
So, given that the firmware is giving “a 404 error” - should I consider it kaput?
P.S. I read earlier here that Zorin OS ‘kills usb’s’. I used one to transfer the OS onto the desktop; can’t read it now (at least not on this windows laptop). Thanks for all your help. I plan on supporting you all once I get up-and-running; totally worthwhile cause(s).
No, not at all. At this moment, I am multitasking heavily. scanning the thread, I caught this line, but I have not fully read the details, yet. Dealing with coaching balancing an engine, but will return in a bit.
No, Zorin OS absolutely does not kill USB's.
The thread you read commented that BalenaEtcher, an app for writing to USB sticks, is accused of it. But accusation does not equate to guilt.
I understand how you feel. You took the plunge and at the moment, you are worried that everything is broken and nothing will work. But your hardware was built for windows- We just need to do some troubleshooting, is all.
Let me "undivide" my attention and I will return to this thread- and in the meantime, others may also provide solutions, too.
Ok, a double-post:
TechNut, open a terminal (ctrl+alt+t keyboard shortcut) and paste this line into it
sudo apt update
Please paste the output of that to show which repo entries are giving any errors.
Next, in terminal paste in
sudo apt dist-upgrade
This is to upgrade or add to any packages you need. This action may even resolve your issue... But in case it does not, we stand at the ready over here.
Let's say that your issue with wifi remains after running the above commands.
Let's try building your wifi
In terminal paste in each line
sudo apt install build-essential git
This installs "git" for grabbing some packages from source
Use it to get the packages:
Now use the 'cd' command to change terminal to that directory
cd backport-iwlwifi
Now use the 'make' application to make the build
sudo make
sudo make install
With that built, we need to give root access and instruct the computer to use it. While GUI installers normally do all this for you, we are doing this manually for now. Good Training
Haven’t been able to pick up on this 'til now… really glad to see it’s still possible. Plugged in CPU & Zorin’s still there; just need to keep at it to get internet. I did what you said above - stalled at: Package git not available, but is referred to by another package. This may mean that the pkg is missing, has been obsoleted, or is only available from another source.
E: Unable to locate package build-essential
E: Package ‘git’ has no installation candidate.
This is interesting.
It says git is unavailable?
Git in the current repo:
git version (1:2.17.1-1ubuntu0.7)
build-essential version (12.4ubuntu1)
Before proceeding, can you go to the App Menu and search for and open "Software & Updates". On the first tab when it opens, look near Mid-Bottom for the drop down menu for "Download From:" and ensure that is set to "Main Server?"
Finally figured out to connect cpu directly to internet input…Lots of progress downloading. Only hitch: upon entering “cd backport-iwlwifi” reply: no such file or directory
Then, I got frustrated so I purchased Ultimate (to get help with install). That didn’t seem to make a bit of difference.
The file you downloaded may have been updated causing the name to change slightly- just look at the name of the file you downloaded and extracted, and "cd" into that- or open your file manager and click that file open, then right click in the window and select "Open in Terminal" if your FM has that extension.
