Your command:
➜ ~ sudo apt install linux-generic-hwe-18.04 linux-firmware
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
Oh My Zsh Reccomended Command:
➜ ~ sudo dpkg --configure -a
Setting up linux-headers-5.4.0-58-generic (5.4.0-58.64~18.04.1) ...
/etc/kernel/header_postinst.d/dkms:
* dkms: running auto installation service for kernel 5.4.0-58-generic
Error! This module/version has already been built on: 5.4.0-58-generic
Directory: /var/lib/dkms/nvidia/450.80.02/5.4.0-58-generic/x86_64
already exists. Use the dkms remove function before trying to build again.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
make -j12 KERNELRELEASE=5.4.0-58-generic -C /lib/modules/5.4.0-58-generic/build M=/var/lib/dkms/virtualbox/5.2.42/build.....
Signing module:
- /var/lib/dkms/virtualbox/5.2.42/5.4.0-58-generic/x86_64/module/vboxpci.ko
- /var/lib/dkms/virtualbox/5.2.42/5.4.0-58-generic/x86_64/module/vboxnetflt.ko
- /var/lib/dkms/virtualbox/5.2.42/5.4.0-58-generic/x86_64/module/vboxnetadp.ko
- /var/lib/dkms/virtualbox/5.2.42/5.4.0-58-generic/x86_64/module/vboxdrv.ko
Secure Boot not enabled on this system.
DKMS: build completed.
vboxdrv.ko:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/5.4.0-58-generic/updates/
vboxnetadp.ko:
- Original module
- Installation
vboxnetflt.ko:
- Original module
- Installation
vboxpci.ko:
- Original module
- Installation
depmod...........
DKMS: install completed.
...done.
Setting up linux-modules-extra-5.4.0-58-generic (5.4.0-58.64~18.04.1) ...
Setting up linux-image-generic-hwe-18.04 (5.4.0.58.64~18.04.53) ...
Setting up linux-headers-generic-hwe-18.04 (5.4.0.58.64~18.04.53) ...
Setting up linux-generic-hwe-18.04 (5.4.0.58.64~18.04.53) ...
Processing triggers for linux-image-5.4.0-58-generic (5.4.0-58.64~18.04.1) ...
/etc/kernel/postinst.d/dkms:
...done.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.4.0-58-generic
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8125a-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168fp-3.fw for module r8169
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Generating grub configuration file ...
Found theme: /usr/share/grub/themes/zorin/theme.txt
Found linux image: /boot/vmlinuz-5.4.0-58-generic
Found initrd image: /boot/initrd.img-5.4.0-58-generic
Found linux image: /boot/vmlinuz-5.4.0-56-generic
Found initrd image: /boot/initrd.img-5.4.0-56-generic
Found linux image: /boot/vmlinuz-5.4.0-54-generic
Found initrd image: /boot/initrd.img-5.4.0-54-generic
Found Windows Boot Manager on /dev/sdc1@/efi/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for EFI firmware configuration
done
full upgrade command:
➜ ~ sudo apt full-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
linux-headers-5.4.0-54-generic linux-hwe-5.4-headers-5.4.0-54
linux-image-5.4.0-54-generic linux-modules-5.4.0-54-generic
linux-modules-extra-5.4.0-54-generic
The following packages have been kept back:
wine-stable winehq-stable
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Your reccomended command, again, after the oh my zosh reccomendation:
linux-firmware is already the newest version (1.173.19).
linux-generic-hwe-18.04 is already the newest version (5.4.0.58.64~18.04.53).
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Should I uninstall wine? I dont use it that much.
Should I follow the terminal’s advise, I am using ohmyzosh?
Should I use sudo autoremove?
