I installed synaptic, then installed through synaptic first. I used the code below for support measures.
So I attempted step two and Im confused why it failed…
Did I miss a step?
Should I move on to step three?
I appreciate the help!
➜ ~ sudo apt-get upgrade -y
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
wine-stable wine-stable-amd64 wine-stable-i386:i386 winehq-stable
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
➜ ~ sudo apt-get install r8168-dkms
r8168-dkms is already the newest version (8.045.08-2ubuntu1).
➜ ~ dkms status
Error! Could not locate dkms.conf file.
File: does not exist.
Try attaching the screenshot using the “upload” button when you’re writing a post. But you don’t have to attach your earlier screenshot. Can you show me what you have for the “Other Software” tab? Just your tab, no need to post a picture of the thread where I posted my settings. The google drive pic was very difficult to see.
After that, try whichever of the steps here have not been tried.
I don’t see two repositories: packages.zorinos.com and ppa.launchpad.net/zorinos/patches
I strongly recommend you check yourself as well by comparing yours to Software Updater settings - I’m only human and could have missed others.
Once you add these (and any others that may be missing), run the software updater and install any necessary updates. I also recommend that you change the “Download From” to Main Server, if you haven’t so already.
See how it goes after the updates.
Given that the adapter worked fine for two weeks, there is a chance that the hardware may also be failing.
