Hi, I installed the Beta of Zorin OS 18 and a found a few minor glitches which I would like to report to help the developers. Is this possible? If so, where? Thanks!
"You can do so by launching the "Send Feedback" shortcut in the taskbar or Zorin Menu in the Zorin OS 18 Beta."
Extract from Zorin blog:
"If you notice any issues or would like to suggest improvements while using the Zorin OS 18 Beta, please leave us feedback about it. You can do so by launching the “Send Feedback” shortcut in the taskbar or Zorin Menu in the Zorin OS 18 Beta. Your feedback will help us make the final release of Zorin OS 18 even better."
You can do like the other's described and to that, You can post Your Issue in this Thread:
