I'm confused on which driver to install for this USB wifi adapter.
The disk came with fedora driver. Not sure what chipset is in this adapter.
Can you check if this helps?
Some info I found on Amazon that may answer some of your questions.
Note they suggest use a USB2.0 port not a USB3.0 port.
Also that it should be plug-and-play on Linux without extra drivers.
What if his device has no usb 2.0 ? My laptop only came with usb 3.0. I see alot of users having trouble with that RT5372 card on ubuntu.
Well this item from @FrenchPress may help in that case. In quest for Linux compatible WiFi
