Okay, this is the story:
I have files on a separate partition that I want to access from different OS's, I often work on 10 or more files at the same time and when I stop and shut down the next time I need to open the editor (Pulsar) with all the files in tabs still there.
I was able to add these files as a projectfolder to Pulsar but every time I rebooted Pulsar couldn't find the directory anymore, only after I opened it with the "files"-application first.
That was solved after editing the Fstab but I need those files for other applications too like Apache and thus edit the documentroot in the apache-settings, but with the new path/to/my/files being:
/mnt/F0E4C80BE4C7D1D0 ntfs-3g defaults,umask=022,uid=1000,gid=1000 0 0/Websites
Apache fails to start
1.: And that's it: I just need Pulsar to remember the last items I was working on and load the projectfolder after I start it.
2.: Right-clicking on a file and use "open with", does not work for Pulsar, only for the default text-editor, which is okay for editing a simple file, but not for a whole project containing PHP-files etc. You need a tool like Pulsar to work on that.
3.: Apache needs to be told where the files are, by default it looks in /var/www/html/ and you can alter that in apache2.conf or httpd.conf (when working with XAMPP)
These three things work flawlessly on Windows, but Zorin obstructs this all.
And there will be more in the future I am sure, this is only the beginning, so I just want to be able to do what I want to do and have all the rights that I need for that and basically for everything that I want to do. But now it's either a fully open OS to everybody or having no access at all, there's nothing in between.
And that's what I mean: Zorin treats all users as morons and is way too overprotective by default, it would be much better if you can grant rights to certain users who know more than average and do other things than being on facebook all day.
So I don't really care if I am granted root-access to everything if there's no in-between possible, if I mess up I just reinstall the OS and start again.
So if anyone can tell me how to work with Zorin with full rights to everything and have Zorin mounting everything that's on my PC (I have more partitions that I want to use in the future) I would be happy with that. Nobody will ever use my laptop and if someone would they can't login because they don't know the password, sounds pretty simple to me.
Really: what happens now is that after installing Zorin it by default takes away all your rights to all your files and folders and you have no choice in that. It would be much better if right after install Zorin comes up with an application in which you can setup user-accounts and priviliges easily, just like every other management-system being an OS like Windows or a website where users can create accounts: there is always an admin who has access to everything and every user-account, but there's no admin-account in Zorin, it's either all or nothing at all.
So if that's it, then please give me all, I want to be able to do everything, even make stupid mistakes of which I will learn, I have all my personal files safely on a separate partition and I back them up on a USB-stick every day and next to that they are on an external harddrive too.
I can ofcourse do sudo bash in the terminal, then I am root@erwin which gives me all the rights. But will that also mount all my partitions by default and grant access to files to applications like Pulsar by default?
I would be very happy if someone can tell me how to have all the possible rights and access to all files and folders with whatever application I use right after logging into Zorin with my user-account.
And yes I have noticed that these packages cause problems, that's why I ditched Opera which was my favorite browser. But if you go to the software-section all these apps seem to be mixed-up, so removing Flatpack and Snap is the first thing that I am going to do, but I do not understand why they are installed by default if they are known to cause problems while Zorin is so keen about keeping the system running smooth, it shouldn't be offering these high-risk applications in the first place.
Really: Googling for solutions is about the riskiest thing that you can do, Google shows you what it wants to show you, not what YOU need and puts the websites with the most chance to conversions and sales on top, even if the articles are 5 years old. Google is not there for you but for it's own bankaccount and telling people how to do things in Zorin by asking Google is about the worst advice you can give, this is where forums like this can be golden.
Thing is: if you go to the Zorin Website everything looks very professional and this forum is an awesome application too. It all radiates professionalism and trustworthyness and the homepage gives a message like: just install Zorin, it's all a piece of cake and then you can go on with your stuff as you were used to.
But the reality is far from that: you're either a noob or a full-stack programmer/developer according to Zorin while it should give you the chance to set up your user-profile easily right after install.
Thank you for coming back on this, I was really ready to ditch Zorin and I already had my Windows-boot-USB ready to repair the MBR but I do not want to go back to Windows and I like a lot about Zorin.
One more thing: I have been holding back on other problems not wanting to overload this forum with issues and trying to find things out on the internet, but like yesterday
- the network-adapter failed again and I had to hotspot-connect the phone and reinstall the drivers.
-On the phone-connection I have full signal, in Zorin one or two levels below full signal and websites are loading not as fast as they should,
-connecting through SSH with the webserver is extremely slow.
-I had installed a small application that shows me another desktop-background image every 5 minutes, today it stopped working, just like that
-and there will be more, because I just started setting up the basic stuff
You see? Zorin is not that stable as it says it is and that is by default and it's usability-level is way too low, if I encounter these problems with my humble level of knowledge then nobody I know will ever be able to use Zorin just like they use Windows and you should not pretend that it's all so stupid simple to switch to Zorin, that's just a commercial lie like you find everywhere on the WWW nowadays especially when Googling. Just be honest and warn people of what they can expect, my 84 year old mother or my wife will never be able to switch to Linux this way.
If you can help me get back on my way and go on with my things without being disturbed by the OS anymore then yes please!
And if I mess up, I will just reinstall Zorin, don't worry, I can handle that.
