Hello, gentlemen of the Zorin OS forum.
Firstly, thank you for the excellent work you do in this forum and for the help you offer.
I am contacting you for the following reason:
Several years ago, I purchased Zorin OS 15.0 Pro (Paid Version) and have enjoyed it for a long time. Currently, I have Zorin OS 15.3 Pro and have gotten a lot of performance and use out of it. Recently, I have tried Zorin OS 16.3 Free version and I also liked it.
So I would like to upgrade to Zorin OS 16.3 Pro, as Zorin OS 15.3 Pro has been outdated for some time now. I have already purchased Zorin OS 16.3 Pro (Paid version) but when I tried to upgrade from Zorin OS 15.3 Pro to Zorin OS 16.3 Pro I encountered a problem.
To do this I have performed the procedure explained in your guide: Upgrade Zorin OS - Zorin Help and when the updater is in step number 4 it informs me that there has been an internal error because it has not been able to complete correctly the check of the update requirements.
The report provided by the system is as follows:
[CHECKING] Started
[CHECKING:Validating Upgrade Attempt] Started
[CHECKING:Validating Upgrade Attempt] Completed
[CHECKING:Checking Filesystem] Started
[CHECKING:Checking Filesystem] Completed
[CHECKING:Creating Necessary Files] Started
[CHECKING:Creating Necessary Files] Completed
[CHECKING:Restarting Apt] Started
[CHECKING:Restarting Apt] Completed
[CHECKING:Simulating Flatpak Transaction] Started
[CHECKING:Simulating Flatpak Transaction] Completed
[CHECKING:Processing Apt Repos] Started
[CHECKING:Processing Apt Repos] Completed
[CHECKING:Updating Apt Repos] Started
[CHECKING:Updating Apt Repos] Completed
[CHECKING:Calculating Upgradeable Packages] Started
[CHECKING:Calculating Upgradeable Packages] Fatal Error: { GDBus.Error:org.debian.apt.TransactionFailed: error-dep-resolution-failed: E:Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages. }
[CHECKING:Calculating Upgradeable Packages] Failed
[CHECKING] Failed
[CHECKING:Restoring System] Started
[CHECKING:Restoring System] Completed
I have spent several hours investigating the error and I believe it is due to an incomplete system dependencies issue or problems with packages. I have tried many things on my system to try to correct it, but have been unsuccessful. The closest thing there would be on your forum is the following: Zorin OS Upgrader: Z15.3 Core to Z16.2 Core fails with errors, but this solution didn't work for me either. Finally, after trying many possible solutions to this issue, I have returned the state of my computer back to the way it was before applying all these possible solutions. Before trying all these possible solutions and trying to update the system, just in case, I made a backup. With which I have the computer in the same state as before, I tried to upgrade and address these possible solutions.
In short, I have Zorin OS 15.3 Pro and I want to upgrade to Zorin OS 16.3 Pro, but I can't because of the error described above which is:
[CHECKING] Failed
I put this other log in case it is of help:
Log time: 2023-06-23 01:05:19.598822
Starting pkgProblemResolver with broken count: 1
Starting 2 pkgProblemResolver with broken count: 1
Investigating (0) packettracer:amd64 < 8.2.1 @iU gK Nb Ib >
Broken packettracer:amd64 Depende on libc6:amd64 < 2.28-0ubuntu1+zorin4 @ii mK > (>= 2.31)
Removing packettracer:amd64 because I can't find libc6:amd64
Done
ERROR:root:Package docker-desktop has no priority set
ERROR:root:Package scrt-sfx has no priority set
Log time: 2023-06-23 01:07:27.861534
MarkPurge python-pexpect:amd64 < 4.2.1-1 @ii gK > FU=1
MarkPurge gir1.2-dbusmenu-glib-0.4:amd64 < 16.04.1+18.04.20171206-0ubuntu2 @ii gK > FU=1
MarkPurge python-ptyprocess:amd64 < 0.5.2-1 @ii gK > FU=1
MarkPurge libhtml-template-perl:amd64 < 2.97-1 @ii gK > FU=1
MarkPurge python-paramiko:amd64 < 2.0.0-1ubuntu1.3 @ii gK > FU=1
I look forward to your help. I remain attentive to your possible solutions.
Thank you very much.
