Hello!
I am having problems to install Wine on Zorin OS 16, when I use the common command on terminal this appears:
It is in portuguese, but the principal error is:
Some packages could not be installed. This could mean that
you requested an impossible situation or, if you are using the
unstable distribution, that some required packages were not
created yet or removed from "Incoming".
The following information may help resolve the situation:
The following packages have mismatched dependencies:
wine : Depends: wine64 (>= 5.0.3-3+zorin2) or
wine32 (>= 5.0.3-3+zorin2)
It depends: wine64 (< 5.0.3-3+zorin2.1~) or
wine32 (< 5.0.3-3+zorin2.1~)
E: Unable to fix issues, you kept (hold) broken packages.
This happens on the end:
Translating it on english:
Reading package lists... Done
W: GPG Error: Index of /wine-builds/ubuntu artful InRelease: The following signatures could not be verified due to the public key not being available: NO_PUBKEY 818A435C5FCBF54A
E: The repository 'Index of /wine-builds/ubuntu artful InRelease' is not signed.
N: Updates from such a repository cannot be done securely and are therefore disabled by definition.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'Index of /ubuntu-audio-dev/alsa-daily/ubuntu focal Release' does not have a Release file.
On the second command:
sudo apt upgrade
This happens:
Basically it's saying if I want to download some files, and when I confirm it, the operation ends. (I know, confusing.)
It's so good to see you here @StarTreker!
Well, I think I am having a little trouble with the second command.
deb https://dl.winehq.org/wine-builds/ubuntu/ focal main
When I add it, this appears:
Now it's time for the translating magic:
Command 'deb' not found, did you mean:
snap den 'den' command (1.2.0-0)
snap dub 'dub' command (1.19.0)
'debc' command from deb devscripts (2.20.2ubuntu2)
deb quilt command 'deb3' (0.65-3)
'dex' command from deb dex (0.8.0-2)
icu-devtools deb 'derb' command (66.1-2ubuntu2.1)
'dab' command from deb bsdgames (2.17-28build1)
'dub' command from deb dub (1.19.0-1build2)
'debi' command from deb devscripts (2.20.2ubuntu2)
'dep' command from deb go-dep (0.5.4-3)
deb 'edb' command edb-debugger (1.0.0-1build3)
See 'snap info ' for additional versions.
I really think that this shouldn't happen.
Thank you! ^^
Pssst, Twilight! Don't tell anyone that I am here. Grab this
Please keep in mind, though...
If the user is going to try
sudo apt install zorin-windows-app-support
then they should not add the wine repo.
IF Zorin-windows-app-supports works for their needs, they should remove the broken wine repo with y-ppa-manager or Software & Updates app (or with the terminal).
IF they are going to not use Zorin-windows-app-support, they should keep the repo and add the key per your suggestion.
So... currently, the instructions in this thread have gotten complicated... I think we need the O.P. to reply with a Clear Plan Forward.
May the force be with you, @prestonEP!
Thank you very much for trying to help me, and also, sorry for taking so long to answer you. Starting from the basics it's a very good option, then, I tried it. Unfortunately, things went a little messy.
The three first commands works fine, but, when I use the Ubuntu 20.04 repository command (which is the one that Zorin OS 16 is based), this happens:
W: GPG Error: Index of /wine-builds/ubuntu artful InRelease: The following signatures could not be verified due to the key not being available: NO_PUBKEY 818A435C5FCBF54A
N: See the apt-secure (8) man page for repository creation and user configuration details.
winehq-stable: Depends: wine-stable (= 6.0.2 ~ impish-1)
It's the same, but, thank you very much for trying! If you know anything more that could help, please share.
Enjoy your stay, @carmar!
Thank you very much for sharing your knowledge. Unfortunately, it didn't worked for me (maybe because I don't know how to use it properly). When I click the "Fix broken packages" things, nothing happens. I don't know if this was supposed to happen, but, I really think that don't.
But, if you have anything more to share, please do, it would be a great help!
I am going to unwrap the red carpet, because @Aravisian is finally here!
Hello!
When I use that command, what I should do next? Sorry, I am really a starter on Linux.
Thank you for the help!
Can you please relay the terminal results of that command? Does it give a final notice that it removed anything?
The purpose of that command is to handle the "You have held broken packages" error.
