Of course. But, please, don't be disappointed, because I think something went wrong.
Don't read it now, wait for the translating magic:
Reading package lists... Done
Building dependency tree
Reading status information... Done
Some packages could not be installed. This could mean that
you requested an impossible situation or, if you are using the
unstable distribution, that some required packages were not
created yet or removed from "Incoming".
The following information may help resolve the situation:
The following packages have mismatched dependencies:
zorin-windows-app-support : Depends: wine or
winehq-stable but will not be installed
It depends: playonlinux but it will not be installed
It depends: wine32:i386
E: Unable to fix issues, you kept (hold) broken packages.
This is getting a little bit complicated, right?
Thank you for the help!
Err:19 Index of /ubuntu-audio-dev/alsa-daily/ubuntu focal Release
404 Not Found [IP: 91.189.95.85 80]
W: GPG Error: Index of /wine-builds/ubuntu artful InRelease: The following signatures could not be verified due to the public key not being available: NO_PUBKEY 818A435C5FCBF54A
E: The repository 'Index of /wine-builds/ubuntu artful InRelease' is not signed.
N: Updates from such a repository cannot be done securely and are therefore disabled by definition.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'Index of /ubuntu-audio-dev/alsa-daily/ubuntu focal Release' does not have a Release file.
This error is following me, but I won't give up so easy.
Thank you!
Those errors are no big deal. They just mean that those repositories in your sources list are not working. Remove them:
Open software & updates from teh app menu and then move to the other software tab.
Scan for the WINE repository and click on it to select it, then click the remove button at the bottom.
Repeat this for the ubuntu-audio-dev alsa repo...
once done, close Software & Updates and it will refresh, then open terminal and test
Install any version of wine through PlayOnLinux - see #4 on that link. That’s if you’re comfortable just using POL - that’s what I do. I stopped using vanilla Wine a while back.
OK! WE HAVE SOMETHING NEW AND GOOD HERE.
This happened, and I am pretty sure that it's not a error. What should I do next?
Dont worry. Let me just... Translation magic :
114 kB downloaded in 2s (52.0 kB/s)
6 packages can be upgraded. Run 'apt list --upgradable' to see them.
Nothing wrong happened (I think). The mistakes are gone!
Answering your questions:
1 - Not that I remember.
2 - I have tried to download the POL, but, almost the same errors that happened with Wine happened with it.
0 updated packages, 142 new packages installed, 0 to be removed and 0 not updated.
You need to download 115 MB of files.
After this operation, an additional 1,027 MB of disk space will be used.
Do you want to continue? [Y/n] Y
Abort.
