Ralink RT3290 wifi not working
I installed Zorin OS lite on my hp pavillion 2000 laptop. After installation, it worked quite nicely. However, I am having issues related to wifi connectivity. After connecting with my wifi, it works properly for 2-3 minutes. Then, my internet stops working. Although the laptop remains connected to the wifi(shown in the panel ) but internet doesn’t work. If I disable the wifi and enable it again, then it begins working again for another 2-3 minutes. Then the problem repeats. I need to disable and enable the wifi again and again to continue using internet. How can I solve this problem permanently?
Welcome to the forum joybhowmik
Could you please tell your Wireless Adapter information?
In terminal:
sudo lshw -C network
In the meantime, you might try disabling ipv6 and setting static ipv4.
sudo nano /etc/sysctl.conf
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
In terminal, use nano as a text editor:
sudo nano /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
When the editor opens, change "wifi.powersave = 3" to "wifi.powersave = 2"
Here is the wireless adapter information:
*-network
product: RT3290 Wireless 802.11n 1T/1R PCIe
vendor: Ralink corp.
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlo1
version: 00
serial: 48:5a:b6:99:d5:81
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rt2800pci driverversion=5.4.0-47-generic firmware=0.37 ip=192.168.0.105 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:16 memory:c2510000-c251ffff
*-network
product: RTL810xE PCI Express Fast Ethernet controller
physical id: 0
bus info: pci@0000:08:00.0
logical name: eno1
version: 05
serial: a0:1d:48:ff:69:2d
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=MII
resources: irq:19 ioport:2000(size=256) memory:c2404000-c2404fff memory:c2400000-c2403fff
Some online solutions, but I recommend waiting for Aravisian’s response.
  1. https://askubuntu.com/questions/253632/how-do-i-get-a-ralink-rt3290-wireless-card-working
  2. https://webwiks.com/techcorner/get-ralink-rt3290-wifi-work-linux-distribution/
RealTek 3290 PCIExpress…
It’s a bit tricky since it does work when rebooted but not after a while. Normally, we would look to finding and installing the correct drivers. But that it works at first, implies the drivers and the Kernel are working together.
It sounds like the signal is falling apart the longer the card is used.
If this is a Notebook (laptop), not a Desktop PC, I would suggest checking the Hardware First Thing. If the case feels hotter in the area that the Network Card is, you may be looking at hardware failure. These two symptoms, signal loss with use and overheating- usually mean the card is on its last legs.
Not Always… so test and check… But be mentally prepared.
IF the Card is going out… Most folks just pick up a WiFi adapter like a TP-Link.
I the card is still good, there may be something else going on there we can try some fixes on.
Sorry for the late reply. I do have an usb wifi adapter. But how can I configure it in linux in a way that the internal wifi gets disabled and wifi then runs from the usb wifi adapter?
Lastly, I am using Zorin OS alongside Windows, so if I disable the internal adapter in linux, will it also get disabled from the windows part too? (N.B.: It works fine in Windows)
This depends on the drivers and chipset- how you install it. Many work out of the box, since they use the same drivers and chipset. If the device is well supported, this will happen and you will not need to do anything.
Otherwise, when you install the drivers, you then set the chipset of the WiFi device to autostart.
As above, you would not need to disable it, just prefer the other. But if you did disable it, this would effect only Zorin OS.
Hey bro, followed your advice and connected an external usb wifi adapter, no new drivers were needed, however, the same thing happened again. At first, the wifi was connected without any interruption but after a few minutes, the internet stopped working and I needed to disable and enable wifi again to connect to internet. Basically, same as before, is it any software issue or settings that I could try to change? Eagerly waiting for your reply.
I had a similar issue months ago. The net would slowly degrade and while showing me as connected, not actually connect. I got used to turning off and on the connection from my computer after trying many fixes. I happened to get a note from my ISP saying my router was getting old and they offered to provide a new one. I accepted and it arrived- I hooked it up.
I didn’t really think about it.
But that above problem went away with that action.
Honestly, I do not think any settings are involved. If if was Settings, then your settings would either connect and work or not connect and not work.
I think it is not the hardware itself because if it was, the USB adapter would have shown different behavior.
Is it software conflict, driver conflict, x conflict or kernel conflict? Yes, all of these are possible and diagnosing and troubleshooting is… tedious…
It may be as simple as using a different driver:
if the one you have works- but does not work well.
If may be that the firmware needs updating as I see in your OP that the configuration is rt2800pci and the firmware is rtl8105e.
I'm having this exact problem! Did you get it sorted?
It works fine on my Windows partition so I don't believe it to be the hardware or the network. Exactly the same as you mine connects for a few minutes in Zorin (I have managed to download something and use Google so it definitely does work) but then will not connect again unless I disable the network adapter and re-enable it.
Aravisian is right. I was using a Medialink router several years ago, I had it for about 3-years. Before I went to bed the internet and network were stilling working, when I got up the next morning, everything was dead.
I did as much troubleshooting as I could, but not only were my internet and network dead from the router, but I couldn't even get into my router's configuration. Power cycling did no good, nothing I could do could fix it, the router was dead.
I bought a new router, problem solved, and I've had my router already for several years. Eventually, when money allows, I'd like to upgrade to a faster router, but this one is still going strong for now.
I am also facing the same problem here after reboot rt3290 wifi card works for few seconds then disconnects and never connects back doesn't even scans for the network. I have a live papermint usb I thied the wifi on papermint works plug and play so I was thinking any one can figure out what are the different settings that works in papermint os. Papermint karnal 6.1 zorin-6.8
@Avik Did you try the mentioned solution of @Aravisian to disable wifi powersaving?
I actually did it didn't solve it. The thing it stays connected till the time I have ethernet connection sounds funny may be but yes I thied that I first connected ethernet and then connted wifi it stays connected but as soon as I disconnect ethernet wifi drops
This sounds a lot like network manager routing and metric conflicts.
There are some complicated tweaks you can try to apply to set the routing metric firmly in place to try to prevent it spinning out:
(The network names here are examples and you must use your network name)
nmcli connection modify "WiFiSSID" ipv4.route-metric 600
nmcli connection modify "Wired connection 1" ipv4.route-metric 100
But whether they work is hit or miss.
The driver is unstable on Linux, though using a much older kernel seems to help (Kernel 4.18)
Most users do not bother with the headache. An inexpensive wifi dongle like this one that has good solid linux driver support is the most pain free solution.
I understand but I I still wanted to see if I can get it to work. on this same system I thied live papermint os/fedora42 both seams to work fine with wifi never drops only ubuntu based systems. Papermint is 6.1 karnal so they must be doing something here to make it work right ?
Does Wifi work booting from Zorin live USB stick and "Try Zorin" mode?
I agree that they seem to have something, maybe a backported patch, that helps...
Ubuntu and Ubuntu based seem to struggle:
https://forums.linuxmint.com/viewtopic.php?t=311625
But are not alone:
Peppermint OS is based on Debian, which is the same base Ubuntu builds upon.
Forpli asks the right question: Do the generic drivers in the LiveUSB seem to work?
When you have Dualboot with Windows please disable fast startup in Windows and secure boot and fast boot in your BIOS while using Linux.
What happens when you not plug in ethernet? Do you then have WIFI?
No I even tried disable both drivers proprietary and opensource one by one to see if they conflict. And I did tried zorin live usb so here is what I found not working - zorin kubuntu, all ubuntu flavour, porteus, porteux, slax, working- all fedora, all direct debian derivatives - papermint,lmde,tails so I think the pach is with dabian
