I will wait to see if @swarfendor437 's suggestions above help. This is because they are two very different directions. His suggestion is to blacklist the snd-hda-intel driver whereas mine is to modprobe it
modprobe: ERROR: ../libkmod/libkmod-module.c:191 kmod_module_parse_depline() ctx=0x560b3d0702a0 path=/lib/modules/5.15.0-87-generic/kernel/sound/hda/snd-intel-dspcfg.ko error=No such file or directory
modprobe: ERROR: could not insert 'snd_hda_intel': Unknown symbol in module, or unknown parameter (see dmesg)
To me all that sounds like the sys points to a non present HW!
Must check the BIOS settings again to see what's up there - maybe it just needs a patch or downgrade
But whatever - Idk - am just a stupid MS admin-on-search for a well working OS
Reboot - but bap the esc key (if needed) to go to the Grub menu at boot.
Select Advanced Options for Zorin and then select Zorin on 5.15.0-83 to boot up (do not select the one with the Recovery Option).
Once you reach the desktop, open terminal and check that you are running on the 5.15.0-83 kernel
uname -r
Now test sound - test modprobing it again if needed:
