Hi Please can someone who knows linux commandline much better than me help me out
how do i set the touch pad to rotate through 90 degrees
if i open the terminal and"input -list" i get the following
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ SINO WEALTH USB Composite Device Mouse id=8 [slave pointer (2)]
⎜ ↳ Goodix Capacitive TouchScreen id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Video Bus id=6 [slave keyboard (3)]
↳ SINO WEALTH USB Composite Device id=7 [slave keyboard (3)]
↳ SINO WEALTH USB Composite Device System Control id=9 [slave keyboard (3)]
↳ SINO WEALTH USB Composite Device Consumer Control id=10 [slave keyboard (3)]
↳ SINO WEALTH USB Composite Device Wireless Radio Control id=11 [slave keyboard (3)]
↳ bytcr-rt5640 Headset id=12 [slave keyboard (3)]
↳ axp20x-pek id=14 [slave keyboard (3)]
↳ gpio-keys id=15 [slave keyboard (3)]
↳ gpio-keys id=16 [slave keyboard (3)]
↳ Goodix Capacitive TouchScreen id=17 [slave keyboard (3)]
but when i try and use the following to rotate it xinput set-prop '<device name>' 'Coordinate Transformation Matrix' <matrix-elements-rowwise>
`xinput set-prop ‘Goodix Capacitive TouchScreen’ ‘Coordinate Transformation Matrix’ 0 1 0 -1 0 1 0 0 1
i get "Warning: There are multiple devices matching ‘Goodix Capacitive TouchScreen’.
To ensure the correct one is selected, please use the device ID, or prefix the
device name with ‘pointer:’ or ‘keyboard:’ as appropriate.
unable to find device Goodix Capacitive TouchScreen" and dont know how to correct it
