Hey there everyone ! I've been using Zorin 17.3 for two months now, and overall I'm loving it. There's only one slight issue I can't seem to find a fix for : my screen never goes blank when i'm idle (nor does it lock), even though Screen Blank setting (Settings/Power/Power Saving Options/Screen Blank) is set to 1 minute.
On the other side, although I typically leave Automatic Suspend disabled, it does correctly automatically suspend if I set it to, so I guess it's not idle state not being triggered or anything. Power Mode setting is set to Performance, but I tested with Power Saver and no change.
I looked around here and on other forums (like here or here), but never found my exact problem (except on this unanswered question ). I checked various gnome settings :
org.gnome.desktop.session idle-delayreturned 60, as expectedorg.gnome.desktop.screensaver idle-activation-enabledwas set to true, as expectedorg.gnome.desktop.screensaver lock-enabledwas set to true. I tried setting it to false since my end goal is to have a simple screensaver without locking out, but doesnt work in either case. I set it back to true.org.gnome.desktop.screensaver lock-delaywas initially set to 0. I thought it might be the root of the problem, but setting it to 60 does not change anything.
Some additional informations :
- I have 2 monitors (Main is n°2, using DVI->HDMI, 59.94HZ, 1080p, Secondary is n°1, using HDMI->VGA, 60Hz, 1080p)
- My graphics output are on a nvidia 3090, the CPU has no graphic option. I tested every driver available at some point to solve another issue, now the latest available are installed.
- This is a Windows dual-boot, and both OS are on the same physical SSD drive
Do you have any idea what could be causing this ?
