Screen blinks, causes videos, images, gifs, etc. to halt or to be unviewable, games to straight up lag games for a bit, etc
This problem has persisted for about a week at this point, the screen blinks and it halts or outright makes videos, images, gifs, unviewable, both on the local pc, on applications, web browsers, causes games to lag for a bit after it blinks, and occasionally I see the funny glitchy Windows XP effect for when a laptop has had enough (this has been going on for a bit longer, I opted to ignore it).
Now my AMD GPU is on low usage, my cpu is on low usage, so I am really left wondering what to check software wise before going to the hardware as this didnt happen until god knows how many updates ago and so I am asking here for help.
Did You received a Kernel Update? If yes, You could choose over the GRUB Menu the older Kernel and then check if it behaves normal again.
What for an AMD GPU do You have? And what for a CPU? Does Your System run in Wayland or X11? You can check that with the Command echo $XDG_SESSION_TYPE via Terminal. Are Secure Boot and Fast Boot in BIOS disabled?
After following @Ponce-De-Leon advices, I would suggest you to test Liquorix kernel by following this tutorial
Liquorix have a really good management of AMD GPU, I use it and have no problem
AMD Radeon RX 6700 XT
Ryzen 9 9900X 12-Core Processor
Xorg X11
Secure Boot and Fast Boot off
Did I receive Kernel Update? Maybe? :person_shrugging:
Do I have to install Liquorix kernel?
last one shows hit enter to continue. Hmm I also see some things thats are not needed like the jammy stuff. Need to correct those errors open the updater then the settings on left then the other software tab and remove any in there that say Jammy as zorin 18 uses noble
First, like @wesoliv429 suggested, you have to remove all jammy repos, and after that make a good update before installing liquorix or anything else !
Step by step guide please.
open this then at left settings
then at top other software......uncheckmark all the ones in the list that says jammy inrealease at the end>>you may have to enter your password several times when removing them
hit close then reload and close that
Once done run sudo apt update && sudo apt upgrade and see if there is any more errors if so post results here.... and only if it is error free then you can install the liquorix kernel using
sudo add-apt-repository ppa:damentz/liquorix
then
sudo apt install linux-image-liquorix-amd64
dont run these till you have no more errors. post errors here so we can help you correct them
You could switch to Wayland to check if it behaves the same, worse or better. to switch, go to the Login Screen. Click there on Your Profile so that the Password Field appears. When it is appeared, You should see in the bottom right Corner a Gear Icon click on it. Choose there the Option ''Zorin Desktop'' and then log in.
You have added cappelikan and the Liquorix PPA which wasn't neccessary. From the Link that @Nourpon has posted, You only had to follow the 2 Steps on:
For the Error with this lunarg vulkan Repo Error:
Open the Terminal and type ls /etc/apt/sources.list.d and post the Output here.
That could help. Also it would be worth to think about combining it with a more current Mesa Driver (Graphics Driver).
But first, we should bring a bit Order in and take care about the other Stuff one by one.
Right please tell me exactly which ones to uncheck so that I dont do any mistakes.
Not just uncheck but remove
Ok now what?
Please do this:
Here.
Do that in terminal and give us the output
sudo rm /etc/apt/sources.list.d/lunarg-vulkan*
sudo apt update
ls /etc/apt/sources.list.d/
Ya what @Nourpon posted
did you remove them for other software area?
Removed what Nourpon told me, did reload and we got this.
