Hi, I am a newbie and just installed zorin on my xps 13 2in1.
I noticed that I have a line or lag when I am scrolling in the upper third of my screen.
@Aravisian was so kind to help me with this issue when playing video but I haven't fixed it yet.
Here is what I am running for drivers:
hdky@hdky-XPS-13-7390-2-in-1:~$ sudo lshw -C video
[sudo] password for hdky:
*-display
product: Iris Plus Graphics G7
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 07
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 mode=1920x1200 visual=truecolor xres=1920 yres=1200
resources: iomemory:600-5ff iomemory:400-3ff irq:156 memory:603d000000-603dffffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff
I cant even tell if it is a video issue since they work fine but occasionally have the same line in the screen.
Apart from that I love zorin so far
add-on:
I notice the clock on the bottom right having a last digit cut in half. Many of these little glitches make me rethink If I should install windows again or is there a way to reset the zorin install?
Headphone jack is crackling too.
Thank you, I followed the first steps and still have the same issue. Now I am on askubuntu and after typing this cmd: ```
sudo apt-get install xserver-xorg-video-intel
hdky@hdky-XPS-13-7390-2-in-1:~$ sudo apt-get install xserver-xorg-video-intel
Reading package lists... Done
Building dependency tree
xserver-xorg-video-intel is already the newest version (2:2.99.917+git20200226-1).
xserver-xorg-video-intel set to manually installed.
The following package was automatically installed and is no longer required:
libigdgmm11
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
How can I upgrade this. Could this be the problem?
chafa gsfonts imagemagick-6-common libchafa0 liblqr-1-0
libmagickcore-6.q16-6 libmagickwand-6.q16-6
Suggested packages:
libmagickcore-6.q16-6-extra
libmagickcore-6.q16-6 libmagickwand-6.q16-6 neofetch
0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
Need to get 5 308 kB of archives.
After this operation, 14.3 MB of additional disk space will be used.
Get:1 Index of /ubuntu/ focal/universe amd64 liblqr-1-0 amd64 0.4.2-2.1 [27.7 kB]
Get:2 Index of /ubuntu/ focal-updates/universe amd64 imagemagick-6-common all 8:6.9.10.23+dfsg-2.1ubuntu11.4 [60.9 kB]
Get:3 Index of /ubuntu/ focal-updates/universe amd64 libmagickcore-6.q16-6 amd64 8:6.9.10.23+dfsg-2.1ubuntu11.4 [1 647 kB]
Get:4 Index of /ubuntu/ focal-updates/universe amd64 libmagickwand-6.q16-6 amd64 8:6.9.10.23+dfsg-2.1ubuntu11.4 [303 kB]
Get:5 Index of /ubuntu/ focal/universe amd64 libchafa0 amd64 1.2.1-1 [42.1 kB]
Get:6 Index of /ubuntu/ focal/universe amd64 chafa amd64 1.2.1-1 [29.7 kB]
Get:7 Index of /ubuntu/ focal/universe amd64 gsfonts all 1:8.11+urwcyr1.0.7~pre44-4.4 [3 120 kB]
Get:8 Index of /ubuntu/ focal/universe amd64 neofetch all 7.0.0-1 [77.5 kB]
Fetched 5 308 kB in 2s (3 262 kB/s)
Selecting previously unselected package liblqr-1-0:amd64.
(Reading database ... 270308 files and directories currently installed.)
Preparing to unpack .../0-liblqr-1-0_0.4.2-2.1_amd64.deb ...
Unpacking liblqr-1-0:amd64 (0.4.2-2.1) ...
Selecting previously unselected package imagemagick-6-common.
Preparing to unpack .../1-imagemagick-6-common_8%3a6.9.10.23+dfsg-2.1ubuntu11.4_
all.deb ...
Unpacking imagemagick-6-common (8:6.9.10.23+dfsg-2.1ubuntu11.4) ...
Selecting previously unselected package libmagickcore-6.q16-6:amd64.
Preparing to unpack .../2-libmagickcore-6.q16-6_8%3a6.9.10.23+dfsg-2.1ubuntu11.4
_amd64.deb ...
Unpacking libmagickcore-6.q16-6:amd64 (8:6.9.10.23+dfsg-2.1ubuntu11.4) ...
Selecting previously unselected package libmagickwand-6.q16-6:amd64.
Preparing to unpack .../3-libmagickwand-6.q16-6_8%3a6.9.10.23+dfsg-2.1ubuntu11.4
_amd64.deb ...
Unpacking libmagickwand-6.q16-6:amd64 (8:6.9.10.23+dfsg-2.1ubuntu11.4) ...
Selecting previously unselected package libchafa0:amd64.
Preparing to unpack .../4-libchafa0_1.2.1-1_amd64.deb ...
Unpacking libchafa0:amd64 (1.2.1-1) ...
Selecting previously unselected package chafa.
Preparing to unpack .../5-chafa_1.2.1-1_amd64.deb ...
Unpacking chafa (1.2.1-1) ...
Selecting previously unselected package gsfonts.
Preparing to unpack .../6-gsfonts_1%3a8.11+urwcyr1.0.7~pre44-4.4_all.deb ...
Unpacking gsfonts (1:8.11+urwcyr1.0.7~pre44-4.4) ...
Selecting previously unselected package neofetch.
Preparing to unpack .../7-neofetch_7.0.0-1_all.deb ...
Unpacking neofetch (7.0.0-1) ...
Setting up imagemagick-6-common (8:6.9.10.23+dfsg-2.1ubuntu11.4) ...
Setting up neofetch (7.0.0-1) ...
Setting up libchafa0:amd64 (1.2.1-1) ...
Setting up gsfonts (1:8.11+urwcyr1.0.7~pre44-4.4) ...
Setting up liblqr-1-0:amd64 (0.4.2-2.1) ...
Setting up libmagickcore-6.q16-6:amd64 (8:6.9.10.23+dfsg-2.1ubuntu11.4) ...
Setting up libmagickwand-6.q16-6:amd64 (8:6.9.10.23+dfsg-2.1ubuntu11.4) ...
Setting up chafa (1.2.1-1) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for fontconfig (2.13.1-2ubuntu3) ...
Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
hdky@hdky-XPS-13-7390-2-in-1:~$ sudo apt install neofetch
neofetch is already the newest version (7.0.0-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
hdky@hdky-XPS-13-7390-2-in-1:~$ neofetch
It's in Xfce, Sorry Try the Suggestions in the Link. But, I will Suggest Using Xfce (Lite) version of Zorin. Gnome lags like this are generally fixed by reinstalling it. But, You should try lite this Time
Awesome that worked too. Last thing how can I make the app icons bigger in the taskbar? I am worried that if I scale it up I run into the same issue?
Thanks again so much.
