Hi, despite having the orientation set, my secondary screen flips when I switch the input of my main monitor to another source. How can I force my secondary screen to stay in the orientation that is set?
Try These Please,
If the above does not help, you can also remove the malfunctioning component with:
sudo apt remove iio-sensor-proxy
EDIT:
Just found this while looking through the forum on this issue:
tried these already, no success
i think this somehow worked, but only after rebooting more than once
I have experienced this too... as if the OS needs to really get it out of its system.
Computers are weird...
