Secondary SSD not showing as an install point for Steam
Recently installed a 2tb ssd on my desktop and format is ext4. I can add files to it by going through "Other Locations" in Files but it's not showing up within the storage settings within Steam. Has anyone found a solution?
Which version of Steam do you use? Flatpak or .deb?
Flatpak and version 1763795278 for Steam
  1. Then you have to set up Steam permission in Flatseal.
or
  1. Use the .deb file of Steam.
Tutorial:
Setting up external drives, with Steam Flatpak, using Flatseal.
If you're using Steam flatpak, just give Steam the permissions it needs.
Some apps such as Steam always have some issues with Flatpak, for example the flatpak version of Google Chrome needs additional permissions to add website/PWAs icons to your desktop.
Thank you! Just installed the .deb version of Steam and the second ssd is showing without issue.
