Setting not save , all change not save , sound not work
hi to all
i am new to zorin
after installing zorin ,
sound not work change in setting not save, freedownload manager not work, chrome not work and some app i installed not work
some setting like wifi work fine
add language not work
how do am i?
sorry, english is not my native language, execuse me for miss underestanding
Gday @kia1349 , Welcome to the community.
Can you tell us the computer spec's or brand & model?
Are you using Zorin OS Pro or Lite?
Can you tell us how you made the bootable device? (usb/cd/etc)
Also which program did you use? (Rufus/ balenaEtcher/etc)
Have you check BIOS firmware/Drivers updates?
Thank a lot Ocka
Asus laptop k571gt
Ram 16gb
1- Ssd hard 512 two drives , firt 270gb win11 and second 130gb zorin os pro
2- hdd hard drive 1tb parted to 3 drive
I Created bootable usb with balenaEtcher
And bios is updated
Great,
I would first try using "Rufus" to create usb bootable, this may fix a few things.
Have you disabled fast startup & fast boot?
How to disable fast boot & fsat startup.
In addition to disabling fast boot and fast startup, it is worth a new user looking at this pre-installation advice. Before you install
Ok
I was installed zorin by same usb but in hdd driveall was ok but zorin was very slowly, then i decide ti install it on ssd
Thanks for link
Fast boot was enabled
I try again by rufus and disabling fast boot Then inform you here
Thanks alot again sir
Did this help?
Oh yeah - that will cause some fun issues.
I just reinstalled recently and left secure boot off this time around; no issues. I did have secure boot setup and enabled but, ran into some weird issues.. Now, with SB off, everything seems nominal.
Good luck! Hopefully SB was just causing some hiccups. I know it likes to block drivers..
Thanks :smile:
I hope to install it successfully
No yet
I create again usb with rufus
Disable fast oit from win11 and bios
Now , When boot from usb , it show many error and not load
I am trying to make usb again
And now want to install without Nvidia driver
I hope i install it successfully
Hi again Ocka
I installed fresh zorin again and now all is ok
Thanks for your help​:heart::crossed_fingers:
Good to hear! :sunglasses:
