Sith Empire Theme Suite
Icon Download: https://www.pling.com/p/1709306/
GTK Download: https://www.pling.com/p/1709314/
Apps icons are done
emblems icons are done
folder icons are done
Still needs to be made: Devices, mimetypes (sigh), categories and ofcause make a awesome GTK theme.
I LOVE IT! When will it be released for gnome and xfce???
I just released it at this moment. Check first post
Both Gnome and XFCE.
Sith Empire version 1.0 is released!!!
See more: Sith empire - theme Suite
WOW, downloading!! let's see how your gtk theme works with xfce, for the icons idk if keeping gems icontheme
GTK is basically modified Zorins GTK. So I don't know how much change you'll see there. I'ts mostly Nautilus that have been modified.
not so much change. but when the zorin-appearance transparence you have will be ported to thunar, and when/if this theme will be more redish, i'll love that
The GTK theme was more of a step child and more aimed for the Gnome DE, but I'll see if I can do some XFCE.
Thunar actually handles transparency better than Nemo.
Should be easy.
@SignorCastello , be sure to check in Window Manager Tweaks that compositing is turned ON.
Last tab Compositor
Check on "Enable display compositing."
ok. and then?
And then wait for the xfce theme.
ok...please @Storm release it i'm waitingggg
Which file manager do you use?
