so my software updater was set to all updates and now this am it switched to custom and I can not switch it back
Are your update settings pointing to Main Server instead of your country's local server?
yes i switched to main server still no change
Can you give a screenshot at all to understand exactly what is (or what is not) happening?
sure one second
In such cases, I wonder which file I should edit to achieve what I want ![]()
. This way you force the system to set what you want but it's a last choice.
Can you try and update via a terminal instead by entering:
sudo apt-get update && sudo apt-get dist-upgrade
and report back.
Have you installed any applications other than those in Software or other sources other than official ones?
Looks like that you're using a user's profile that hasn't the permission to set there to All Updates and so it always resets itself to Custom.
I will try either late tonight or tomorrow am as Iām at work
What ?
No, nothing, I was wondering if maybe you were using a new created user profile and maybe that new profile is set by default to not allow changes to certain settings, including that one you're fighting against.
Got it no problem
Try removing howdy first via terminal:
sudo apt remove howdy
Reboot and then try updating again. This is to see if howdy is causing the issue
I think it may but i dont really want to remove howdy, its honestly so much more convenient than typing my password all the damn time
A better and quicker solution would be to boot up with a secure usb key you can create yourself and in addition removes the need to enter sudo password when updating or installing software.
Maybe I will see if I can set that up one of these days then I could remove howdy and see if that fixed the issue
