Hello all,
I've noticed I am missing icons in the icon tray. Don't see my Wi-Fi, Telegram or Proton VPN. Not sure why they disappeared.
Hello all,
Do you have the Indicator plugin enabled in the panel?
you can check that in panel preferences
I think status tray plugin item not included in your panel, right click on taskbar(panel) choice panel - panel preferences and look at Is status tray plugin included, if not , u can add it from click on add and select it.
Both of the above answers are for Zorin OS Lite. Just to provide clarity; as the O.P.'s profile does not currently state the users Edition of Zorin OS.
OP is using Zorin os lite see the title ![]()
One of these days... I will learn how to read.
Thank you that worked!
