I installed zorin os (15.3 education lite) (with dual boot with windows 7)............... When I go with windows 7 I hear sounds of everything which are enabled (also of media like videos) ......But when I go with zorin os I can't hear any sound for anything nor system sounds neither media sounds.......
What should I do to fix it .....please help.... Thanks for any help.
Then launch it from terminal with pavucontrol - a GUI window with the PulseAudio Settings will Pop Up. Please go through each setting and ensure that nothing is muted, that the input and output are all correct and so on.
@Vinit On the feint chance of what fixed my sound fixes yours:
You see the channel labelled "Loopback" on the right side of Alsamixer. Try setting that to "Enabled" i.e. toggle it from Disabled to Enabled.
Then save your Alsamixer setting using sudo alsactl store
Not sure if a Reboot is necessary, but if you do one, go back into Alsamixer and make sure Loopback has stayed Enabled.
See if that makes any difference.
If it doesn't then set Loopback back to "Disabled" and store the setting again.
