I raeburn my image more than 10 time still stuck at undate and other software
FAT L for you
You can use gparted to delete all partitions Except the EFI partition - Do Not Delete That One, then expand your free space into one partition.
Um, what does the EFI partition do? Will it destroy your system when deleted?
Necessary for Bootloader.
Can you restore it when deleted?
yeah, just make a new one. But the O.P. currently seems to have enough troubles as it is.
Maybe let me try another USB to see is it work.
Should I use USB 2.0 or 3.0 for bootable use?
OK I hope it works
If not... You would be wise to PM the link to the site you downloaded the bootleg copy of Zorin Pro to 337harvey and take steps toward earning some trust.
It's a lot easier to help a person that does helpful things.
It means I use Zorin os Pro and go and find 337harvey
I got this error IMG-20210906-210014 — ImgBB
Do I need to disable virtualization Technology and TPM?
Can you help me pls I still stuck at the update and other software. It will not go to another page?
No, Linux runs on anything. No crazy hardware requirements needed.
Should I use Rufus to boot as bootable USB?
Should I use fat32 or ntfs?
USB format FAT32.
