SUGGESTION: Customization in right row of start menu
So I was reading through a topic in here about trying to remove the Zorin Appearance and Gnome Software buttons from the start menu, and while reading their solution ( How to remove "Zorin Appearance" from Menu Lite? - #27 by brunok ), I thought about something:
What if those buttons could be easily modified or deleted? I mean, while it sure is a good default to keep those buttons doing the function that they currently do, adding the ability to change it with something else would be useful. It could be used a bit like the favorites tab in other start menus, or maybe even add the ability to make it open a URL in the default browser, or open a specific file with a program, or a specific directory in nautilus, all of these having been previously specified by the user.
They wouldn't be removing any functionality, as Zorin Appearance and the Software store can be opened from the programs menu already.
The only thing I would be concerned about would be accidental removal or modification where the user does not remember what they did. So maybe best if it is a little bit difficult to do.
Or add a button to "Restore Defaults"
That would bring it back to how it was before accidental removals
I think "Factory Reset" button would be the answer to a lot of issues. As is re-installation :slight_smile:
On Gnome, You have that Customization Option in the ArcMenu Gnome Extension. Maybe Zorin takes that over for a future Update for the Zorin Start Menu. We will see how it is in Zorin 18.
