is this Good to try ?
Another way to limit this is to use Linux's control groups. This is especially useful if you want to limit a process's (or group of processes') allocation of physical memory distinctly from virtual memory. For example:
cgcreate -g memory:myGroup
echo 500M > /sys/fs/cgroup/memory/myGroup/memory.limit_in_bytes
echo 5G > /sys/fs/cgroup/memory/myGroup/memory.memsw.limit_in_bytes
will create a control group named myGroup
, cap the set of processes run under myGroup
up to 500 MB of physical memory with memory.limit_in_bytes
and up to 5000 MB of physical and swap memory together with memory.memsw.limit_in_bytes
. More info about these options can be found here: https://access.redhat.com/documentation/en-us/red_hat_enterprise_linux/6/html/resource_management_guide/sec-memory
To run a process under the control group:
cgexec -g memory:myGroup pdftoppm
Note that on a modern Ubuntu distribution this example requires installing the cgroup-bin
package and editing /etc/default/grub
to change GRUB_CMDLINE_LINUX_DEFAULT
to:
GRUB_CMDLINE_LINUX_DEFAULT="cgroup_enable=memory swapaccount=1"
and then running sudo update-grub
and rebooting to boot with the new kernel boot parameters.
