Hello, what do I need to enter in the console and what should I install to get the effect shown in the attached screenshot?
If you're referring to the system information itself, and not the font color, that's a program called neofetch. You can install with:
sudo apt install neofetch
This guide has some tips on how to customize it further:
As an aside, while neofetch still works fine, it hasn't seen any updates in quite a while. An alternative exists called fastfetch:
But if you really want to have a red font you can do so from the terminal Preferences -> Select your Profile -> Colors, and customize the text color from there.
Tanx
