Hello, I am encountering difficulties when attempting to update and upgrade the python3-apport and python3-problem-report packages on Zorin OS 17.1 Core. These packages remain 'kept back' when I execute the commands sudo apt update && sudo apt full-upgrade. I am perplexed by this issue and would appreciate any assistance in resolving it. I suspect this might be a bug or possibly a conflict with other installed packages.
This is not unusual per se. Did You checked the Software Sources Tab in Software & Updates? It is the first from the left side- Look there if ''Main Server'' ist chosen. Then try it again.
Sometimes Packages are held back because there are not ready at this Moment. Simply wait can help.
In terminal, please run
sudo apt install apport python3-apport python3-problem-report
and that should get everything unhitched and fully installed.
@Aravisian , I had exactly the same issue as reported above, so I copied the command you wrote (thanks!) and pasted it into the terminal, after initially trying to upgrade again - just in case waiting had resolved it. Here is what I got back after running your command:
The following packages were kept back:
Nala was unable to determine why these were held:
python3-apport, python3-problem-report
All packages are up to date.
ruth@ruth-HP-Pavilion-TS-15-Notebook-PC:~$ sudo apt install apport python3-apport python3-problem-report
Reading package lists... Done
apport-symptoms python3-systemd
Suggested packages:
apport-gtk | apport-kde
The following NEW packages will be installed
apport apport-symptoms python3-systemd
The following packages will be upgraded:
2 to upgrade, 3 to newly install, 0 to remove and 0 not to upgrade.
Need to get 287 kB of archives.
After this operation, 1.096 kB of additional disk space will be used.
Get:1 Index of /ubuntu jammy-updates/main amd64 python3-problem-report all 2.20.11-0ubuntu82.6 [11,1 kB]
Get:2 Index of /ubuntu jammy-updates/main amd64 python3-apport all 2.20.11-0ubuntu82.6 [89,0 kB]
Get:3 Index of /ubuntu jammy-updates/main amd64 apport all 2.20.11-0ubuntu82.6 [134 kB]
Get:4 Index of /ubuntu jammy/main amd64 apport-symptoms all 0.24 [13,5 kB]
Get:5 Index of /ubuntu jammy/main amd64 python3-systemd amd64 234-3ubuntu2 [39,6 kB]
Fetched 287 kB in 1s (291 kB/s)
(Reading database ... 333763 files and directories currently installed.)
Preparing to unpack .../python3-problem-report_2.20.11-0ubuntu82.6_all.deb ...
Unpacking python3-problem-report (2.20.11-0ubuntu82.6) over (2.20.11-0ubuntu82.5) ...
Preparing to unpack .../python3-apport_2.20.11-0ubuntu82.6_all.deb ...
Unpacking python3-apport (2.20.11-0ubuntu82.6) over (2.20.11-0ubuntu82.5) ...
Selecting previously unselected package apport.
Preparing to unpack .../apport_2.20.11-0ubuntu82.6_all.deb ...
Unpacking apport (2.20.11-0ubuntu82.6) ...
Selecting previously unselected package apport-symptoms.
Preparing to unpack .../apport-symptoms_0.24_all.deb ...
Unpacking apport-symptoms (0.24) ...
Selecting previously unselected package python3-systemd.
Preparing to unpack .../python3-systemd_234-3ubuntu2_amd64.deb ...
Unpacking python3-systemd (234-3ubuntu2) ...
Setting up python3-problem-report (2.20.11-0ubuntu82.6) ...
Setting up apport-symptoms (0.24) ...
Setting up python3-apport (2.20.11-0ubuntu82.6) ...
Setting up python3-systemd (234-3ubuntu2) ...
Setting up apport (2.20.11-0ubuntu82.6) ...
Created symlink /etc/systemd/system/paths.target.wants/apport-autoreport.path โ /lib/systemd/system/apport-autoreport.path.
Created symlink /etc/systemd/system/timers.target.wants/apport-autoreport.timer โ /lib/systemd/system/apport-autoreport.timer.
Created symlink /etc/systemd/system/sockets.target.wants/apport-forward.socket โ /lib/systemd/system/apport-forward.socket.
apport-autoreport.service is a disabled or a static unit, not starting it.
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
...and that was it.
Yes, it looks like the latest python-apport packages refer to some new packages. Due to this, those upgrades were held back (unless the new packages are installed).
By just doing a full install of those packages instead of upgrading them, the new packages get installed too.
I did the update command before trying the upgrade both times - IDK?
I didn't close the Terminal, so here:
ruth@ruth-HP-Pavilion-TS-15-Notebook-PC:~$ sudo nala update
[sudo] password for ruth:
โญโ Updating Package List โโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโฎ
โNo Change: Repository Mirror for your Cloud Server and Webhosting - Index of /ubuntu/ jammy InRelease โ
โNo Change: Index of /stable/ jammy InRelease โ
โNo Change: https://packages.mozilla.org/apt mozilla InRelease โ
โNo Change: Index of /patches/ jammy InRelease โ
โNo Change: https://ppa.launchpadcontent.net/zorinos/apps/ubuntu jammy InRelease โ
โNo Change: Index of /apps/ jammy InRelease โ
โNo Change: https://ppa.launchpadcontent.net/zorinos/drivers/ubuntu jammy InRelease โ
โNo Change: Index of /zorinos/patches/ubuntu jammy InRelease โ
โNo Change: Index of /drivers/ jammy InRelease โ
โNo Change: https://ppa.launchpadcontent.net/zorinos/stable/ubuntu jammy InRelease โ
โNo Change: Servidor de rรฉplicas do Consorcio CIXUG jammy InRelease โ
โFetched 257 KB in 22s (0 Bytes/s) โ
โฐโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโฏ
2 packages can be upgraded. Run 'nala list --upgradable' to see them.
ruth@ruth-HP-Pavilion-TS-15-Notebook-PC:~$ sudo nala upgrade
โNo Change: Index of /ubuntu jammy-updates InRelease โ
โNo Change: https://ocean.surfshark.com/debian stretch InRelease โ
โNo Change: Index of /ubuntu jammy-backports InRelease โ
โNo Change: Index of /ubuntu jammy InRelease โ
โNo Change: Index of /archive.ubuntu.com jammy InRelease โ
โNo Change: Index of /ubuntu jammy-security InRelease โ
โNo Change: https://ppa.launchpadcontent.net/zorinos/patches/ubuntu jammy InRelease โ
โFetched 0 Bytes in 21s (0 Bytes/s)
So, this is the top part and what I posted above follows directly. I didn't run the list to see what could be upgraded, just the command to upgrade
I do not understand... are you still having an issue?
According to your previous post, all the relevant packages installed fully.
@Aravisian , I appologise - I think you are correct. I was confused by:
On checking it again it comes back as "All packages are up to date". My misunderstanding! Thank you.
