My touchpad is an Alps I2C:
cat /proc/bus/input/devices:
I: Bus=0018 Vendor=044e Product=121e Version=0100
N: Name="AUI1667:00 044E:121E Mouse"
P: Phys=i2c-AUI1667:00
S: Sysfs=/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-AUI1667:00/0018:044E:121E.0001/input/input3
U: Uniq=
H: Handlers=mouse0 event3
B: PROP=0
B: EV=17
B: KEY=70000 0 0 0 0
B: REL=1943
B: MSC=10
And touchpad gestures will not work, and I do not know how to solve it. I tried changing some mouse-related settings in both Settings and in Gnome Tweaks.
Are you using Zorin 15.3 - Lite or Core- or Zorin 16 Beta?
Is this a recent installation and touchpad gestures are new- or an existing installation in which touchegg has stopped working properly?
Oh! Sorry, I forgot to clarify that! It is a brand new installation of ZorinOS 16 (Core, obviously).
Your touchpad is being detected as a mouse, instead of a touchpad.
Sadly the only repair I know of is to Update the Kernel or install a backport kernel.
Have you done
sudo apt full-upgrade
since you installed?
How would that be? I have Linux v5.8.0-50-generic. But I know nothing about backport kernels.
Have you done sudo apt full-upgrade since you installed?
Yes sir.
I am a bit baffled too... the 5.8 kernel should be good.
You might try
sudo apt install --reinstall touchegg
just in case...
Could it be because it is both Alps and I2C? I never tried getting gestures in Linux, but in Windows 10 I don't have all the gestures and (trackpad-related) animations other people get. Also, I installed macOS in this laptop and in there, there is no way to get Alps I2C touchpads to work (anyway, It's a hackintosh so it doesn't make much sense to compare, but maybe that information is useful).
The point is: maybe this trackpad is not very gesture-friendly (however Windows got it to work pretty well, so it would be really nice if there's a way to make it work here in ZorinOS).
can you login with wayland? try that
I installed i2c-tools (didn't work), but I can't modify that in my BIOS.
This laptop is a Lenovo IdeaPad 330-15IKB 81DE.
Yes, I can, but that seems not to be enough to solve this issue.
...And will break everything else...
I solved a version of this here.
