Hi. I purchased Zorin for the love that I can ditch Windows for something that is more newbie friendly. However I am not able to scroll with my touchpad. I use an HP Elitebook. Have already tried shifting to synaptics form the terminal as was mentioned in this link: Can't scroll with touchpad!
Thanks, will definitely give it a try.
In the meanwhile, any other solution that you suggest for this problem? Not having touchpad scrolls drains my productivity bigtime.
I only see mouse-related settings in the settings area. Also, based on the terminal screenshot, is my touchpad not detected? I also tried running Synaptics (syncient) through terminal but that too gives the error that couldn't find synaptic properties.
There are two possibilities that come to mind:
Libinput or the Linux kernel.
Since you had tried installing Xorg-Synaptics trying to troublehoot the issue, it seems unlikely to be Libinput.
You might try either an earlier kernel or a later kernel... Given that at this point, you should be using the 5.13 kernel on Zorin OS through the updates, and it being a 2015 model, I would not assume that a later kernel would help.
