Tracker-miner-fs Indexing and High CPU Usage
Can Tracker-miner-fs indexing be stopped before it starts during startup via changing:
/etc/xdg/autostart/tracker-miner-fs.desktop
to:
/etc/xdg/autostart/tracker-miner-fs.desktop.HOLD
or does it also start at some other time in addition to startup ??
Thanks!
https://stls.eu/blog/2014/02/27/disable-tracker-miner-fs/
Thanks, I'm familiar with removing it, but may want to run it manually later. So, my initial questions remain:
  1. stopping it from starting during startup
  2. does it run at any other time automatically.
Thanks!
This is a Gnome-Dependent service. As such, toggling it does not work so easily.
You can mask the service to stop it from indexing:
systemctl --user mask tracker-extract-3.service tracker-miner-fs-3.service tracker-miner-rss-3.service tracker-writeback-3.service tracker-xdg-portal-3.service tracker-miner-fs-control-3.service
Then run:
tracker3 reset -s -r
A reboot is required to see the change.
You can start the service running again by unmasking it:
systemctl --user unmask tracker-extract-3.service tracker-miner-fs-3.service tracker-miner-rss-3.service tracker-writeback-3.service tracker-xdg-portal-3.service tracker-miner-fs-control-3.service
As above;
