Trying zorin OS stuck
Hello , i eventually got to a screen where I clicked try Zorin OS then a whole list of checking messages appears but my screen is blinking and seems to be stuck at:
Checking ./Casper/filesystem.squashfs
_
Any ideas ?
It may be corrupt. Try re-download the .iso file.
...and check the SHA256 of the downloaded .iso file against the Zorin published value. That way you confirm the file is good to use and not corrupt.
Some basic pre-installation advice here: Before you install
