I used to be able to unminimise/unminimize/un-minimise minimized/minimised windows from the dock on Zorin OS 16 Pro and also when I ran the upgrade to Zorin OS 17 Pro.
But after accidentally deleting my .config folder and this being replaced by the OS with default settings, this no longer works
I don't recall having to do any special settings originally.
Here is a video of what happens.
Because this has worked before, I know it can be made to work again. Which will bring me back to the wonderful polished world of Linux on a touchscreen which Zorin excels at, as opposed to other shoddy half-baked self-excusing distros.
Because this has worked before, the only thing I can do right now is to reinstall ZorinOS 16 Pro observed it working there and then upgrade to Zorin OS 17 Pro, where it also had worked and then backup my .config settings and do a beyond compare diff between them and the default to explain here.
But instead of going through that re-install procedure, I'd prefer some advice that could take me to a solution quicker.
