Upgrade from Zorin 15 to Zorin 16 problem
root@Zorin15:/home/mike# apt upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 libzpool2linux : Depends: libnvpair1linux (>= 2.0.4-0york0~18.04) but 0.8.4-1~18.04.york0 is installed
              Depends: libzfs2linux (>= 2.0.4-0york0~18.04) but 0.8.4-1~18.04.york0 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
root@Zorin15:/home/mike# apt --fix-broken install
Correcting dependencies... Done
  efibootmgr libabw-0.1-1 libcdr-0.1-1 libcmis-0.5-5v5 libe-book-0.1-1 libegl1-mesa libeot0 libepubgen-0.1-1
  libfreehand-0.1-1 libfwup1 libheif1 libllvm7 libllvm8 libllvm8:i386 libllvm9 libllvm9:i386 libmspub-0.1-1
  libmwaw-0.3-3 libnvidia-cfg1-418 libnvidia-cfg1-430 libnvidia-cfg1-440 libnvidia-cfg1-450 libnvidia-common-418
  libnvidia-common-430 libnvidia-common-440 libnvidia-common-450 libnvidia-compute-418 libnvidia-compute-430
  libnvidia-compute-430:i386 libnvidia-compute-440 libnvidia-compute-440:i386 libnvidia-compute-450
  libnvidia-compute-450:i386 libnvidia-decode-418 libnvidia-decode-430 libnvidia-decode-430:i386 libnvidia-decode-440
  libnvidia-decode-440:i386 libnvidia-decode-450 libnvidia-decode-450:i386 libnvidia-encode-418 libnvidia-encode-430
  libnvidia-encode-430:i386 libnvidia-encode-440 libnvidia-encode-440:i386 libnvidia-encode-450
  libnvidia-encode-450:i386 libnvidia-extra-440 libnvidia-extra-450 libnvidia-fbc1-418 libnvidia-fbc1-430
  libnvidia-fbc1-430:i386 libnvidia-fbc1-440 libnvidia-fbc1-440:i386 libnvidia-fbc1-450 libnvidia-fbc1-450:i386
  libnvidia-gl-418 libnvidia-gl-430 libnvidia-gl-430:i386 libnvidia-gl-440 libnvidia-gl-440:i386 libnvidia-gl-450
  libnvidia-gl-450:i386 libnvidia-ifr1-418 libnvidia-ifr1-430 libnvidia-ifr1-430:i386 libnvidia-ifr1-440
  libnvidia-ifr1-440:i386 libnvidia-ifr1-450 libnvidia-ifr1-450:i386 libnvpair1linux libodfgen-0.1-1 libpagemaker-0.0-0
  libreoffice-avmedia-backend-gstreamer libreoffice-pdfimport librevenge-0.0-0 libuutil1linux libvisio-0.1-1
  libwpd-0.10-10 libwpg-0.3-3 libwscodecs0 libzfs2linux libzpool2linux linux-headers-5.0.0-25
  linux-headers-5.0.0-25-generic linux-headers-5.0.0-27 linux-headers-5.0.0-27-generic linux-image-5.0.0-25-generic
  linux-image-5.0.0-27-generic linux-modules-5.0.0-25-generic linux-modules-5.0.0-27-generic
  linux-modules-extra-5.0.0-25-generic linux-modules-extra-5.0.0-27-generic nvidia-compute-utils-418
  nvidia-compute-utils-430 nvidia-compute-utils-440 nvidia-compute-utils-450 nvidia-dkms-418 nvidia-dkms-430
  nvidia-dkms-440 nvidia-dkms-450 nvidia-kernel-common-430 nvidia-kernel-common-440 nvidia-kernel-common-450
  nvidia-kernel-source-430 nvidia-kernel-source-440 nvidia-kernel-source-450 nvidia-utils-418 nvidia-utils-430
  nvidia-utils-440 nvidia-utils-450 rsplib-docs uno-libs3 xserver-xorg-video-nvidia-418 xserver-xorg-video-nvidia-430
  xserver-xorg-video-nvidia-440 xserver-xorg-video-nvidia-450
  libnvpair1linux libuutil1linux libzfs2linux
The following packages will be upgraded:
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/340 kB of archives.
After this operation, 64.5 kB of additional disk space will be used.
(Reading database ... 381375 files and directories currently installed.)
Preparing to unpack .../libnvpair1linux_2.0.4-0york0~18.04_amd64.deb ...
Unpacking libnvpair1linux (2.0.4-0york0~18.04) over (0.8.4-1~18.04.york0) ...
dpkg: error processing archive /var/cache/apt/archives/libnvpair1linux_2.0.4-0york0~18.04_amd64.deb (--unpack):
 trying to overwrite '/lib/x86_64-linux-gnu/libnvpair.so.3.0.0', which is also in package libnvpair3linux 2.1.0-0york2~18.04
Preparing to unpack .../libuutil1linux_2.0.4-0york0~18.04_amd64.deb ...
Unpacking libuutil1linux (2.0.4-0york0~18.04) over (0.8.4-1~18.04.york0) ...
dpkg: error processing archive /var/cache/apt/archives/libuutil1linux_2.0.4-0york0~18.04_amd64.deb (--unpack):
 trying to overwrite '/lib/x86_64-linux-gnu/libuutil.so.3.0.0', which is also in package libuutil3linux 2.1.0-0york2~18.04
Preparing to unpack .../libzfs2linux_2.0.4-0york0~18.04_amd64.deb ...
Unpacking libzfs2linux (2.0.4-0york0~18.04) over (0.8.4-1~18.04.york0) ...
dpkg: error processing archive /var/cache/apt/archives/libzfs2linux_2.0.4-0york0~18.04_amd64.deb (--unpack):
 trying to overwrite '/lib/x86_64-linux-gnu/libzfs_core.so.3.0.0', which is also in package libzfs4linux 2.1.0-0york2~18.04
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
root@Zorin15:/var/cache/apt/archives# dpkg -P libnvpair3linux
dpkg: dependency problems prevent removal of libnvpair3linux:
 libzpool5linux depends on libnvpair3linux (>= 0.8.2).
 zfs-zed depends on libnvpair3linux (>= 0.8.2); however:
  Package libnvpair3linux is to be removed.
 zfsutils-linux depends on libnvpair3linux (= 2.1.0-0york2~18.04).
 libzfs4linux depends on libnvpair3linux (>= 0.8.2).
dpkg: error processing package libnvpair3linux (--purge):
 dependency problems - not removing
 libnvpair3linux
Currently, there is no Upgrade Path from Zorin OS 15 to Zorin OS 16.
Can you please detail what steps you tried so far?
Also, please see here:
All I did was
apt update
then
apt upgrade
I was hoping this would upgrade me to Zorin 16.
.... How long had it been since you last did an apt update and upgrade? :expressionless:
