Upgrade to pro failed
When running upgrade to pro multiple timers over the last 2 days, it fails everytime with:
[CHECKING] Started
[CHECKING:Validating Upgrade Attempt] Started
[CHECKING:Validating Upgrade Attempt] Completed
[CHECKING:Checking Filesystem] Started
[CHECKING:Checking Filesystem] Completed
[CHECKING:Creating Necessary Files] Started
[CHECKING:Creating Necessary Files] Completed
[CHECKING:Adding GPG Keys] Started
[CHECKING:Adding GPG Keys] Completed
[CHECKING:Restarting Apt] Started
[CHECKING:Restarting Apt] Completed
[CHECKING:Simulating Flatpak Transaction] Started
[CHECKING:Simulating Flatpak Transaction] Completed
[CHECKING:Processing Apt Repos] Started
[CHECKING:Processing Apt Repos] Completed
[CHECKING:Updating Apt Repos] Started
[CHECKING:Updating Apt Repos] Retrying
[CHECKING:Updating Apt Repos] Fatal Error: { error-repo-download-failed: }
[CHECKING:Updating Apt Repos] Failed
[CHECKING] Failed
[CHECKING:Restoring System] Started
[CHECKING:Restoring System] Error: { error-repo-download-failed: }
[CHECKING:Restoring System] Completed
I have spent days setting up Zorin core and I am happy with it so I decided to upgrade to pro, but it always fails to do so.
Have you added 3rd party repos to your sourcelist? IF so try disable them/it.
Also I read there's some server problems with Ubuntu Lately. I don't know if it was fixed.
The problems with the ubuntu server are not solved yet. Try it tomorrow again. Today many mirrors still don't work and updates/downloads fail. Take a look here:
Only to check that up: When You type sudo apt update && sudo apt upgrade in the Terminal, do You get any Error Messages?
