These are the error I am facing while booting zorin os lite in my hp pc.
Sometimes boot gets stuck to hp logo.
This error usually occurs when the USB port is drawing too much power. I always recommend that when using Linux over USB stick or Installing - Never plug the USB port into a USB Hub or Powered Hub. Use a built in motherboard USB port.
Hi @Aravisian thanks for replying.
When I rebooted it after unplugging my mouse and keyboard which were connected before through usb the error got resolved.
I am new to linux and using zorin lite as primary os, will you plz explain the error in layman terms also any permanent solution for it ?
The problem and the solution are the same on Linux, Mac or Windows. It is a hardware issue, that can affect any system.
The solution is often to avoid low-cost USB hubs or use USB hubs as little as possible.
A post was split to a new topic: USB descriptor read/64, error 32 with USB Ports empty
