I'm having an issue with USB HUB connected to my laptop, started showing the following error messages regarding the disconnect & connect of USB-HUB (dock). This started happening after an upgrade. The same issue is happening to my friend as well. We are using the same laptop and the docking/hub device.
Here is the error I see:
gnome-shell[2054]: Source ID 52960 was not found when attempting to remove it
update-notifier[4676]: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
kernel: [ 9568.085787] hub 4-1.1:1.0: hub_ext_port_status failed (err = -71)
kernel: [ 9568.094026] usb 4-1.1-port3: cannot reset (err = -71)
kernel: [ 9568.102260] usb 4-1.1-port3: cannot reset (err = -71)
avahi-daemon[1025]: Interface enx00e04c9ff229.IPv4 no longer relevant for mDNS.
avahi-daemon[1025]: Leaving mDNS multicast group on interface enx00e04c9ff229.IPv4 with address 10.55.250.11.
avahi-daemon[1025]: Withdrawing address record for 10.55.250.11 on enx00e04c9ff229.
kernel: [ 9568.108622] usb 4-1.1: USB disconnect, device number 34
kernel: [ 9568.108631] r8152-cfgselector 4-1.1.2: USB disconnect, device number 35
kernel: [ 9568.110512] usb 4-1.1-port3: cannot reset (err = -71)
NetworkManager[1296]: <info> [1712798795.9158] device (enx00e04c9ff229): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
NetworkManager[1296]: <info> [1712798795.9477] dhcp4 (enx00e04c9ff229): canceled DHCP transaction
NetworkManager[1296]: <info> [1712798795.9478] dhcp4 (enx00e04c9ff229): activation: beginning transaction (timeout in 45 seconds)
NetworkManager[1296]: <info> [1712798795.9478] dhcp4 (enx00e04c9ff229): state changed no lease
NetworkManager[1296]: <info> [1712798795.9490] policy: set 'env' (wlp3s0) as default for IPv4 routing and DNS
wpa_supplicant[1089]: enx00e04c9ff229: CTRL-EVENT-DSCP-POLICY clear_all
dbus-daemon[1027]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.21' (uid=0 pid=1296 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
kernel: [ 9568.202523] usb 4-1.1.3: USB disconnect, device number 36
systemd[1]: Starting Network Manager Script Dispatcher Service...
dbus-daemon[1027]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
systemd[1]: Started Network Manager Script Dispatcher Service.
kernel: [ 9568.650758] usb 4-1: reset SuperSpeed USB device number 33 using xhci_hcd
kernel: [ 9569.376797] usb 4-1.1: new SuperSpeed USB device number 37 using xhci_hcd
kernel: [ 9569.400834] usb 4-1.1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.56
kernel: [ 9569.400843] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
kernel: [ 9569.400846] usb 4-1.1: Product: USB3.1 Hub
kernel: [ 9569.400849] usb 4-1.1: Manufacturer: GenesysLogic
kernel: [ 9569.419032] hub 4-1.1:1.0: USB hub found
kernel: [ 9569.419719] hub 4-1.1:1.0: 4 ports detected
kernel: [ 9569.708664] usb 4-1.1.2: new SuperSpeed USB device number 38 using xhci_hcd
kernel: [ 9569.729525] usb 4-1.1.2: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
kernel: [ 9569.729536] usb 4-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
kernel: [ 9569.729541] usb 4-1.1.2: Product: USB 10/100/1000 LAN
Can you please help me to fix this issue?
Thanks,
SFK.
