My usb ports are not working and i can’t put my printer or mic in them to use the usb ports as a result I can’t use my computer as I need to .
@Amun Hi and welcomer to the forum. First question is what hardware spec are you running Zorin on? Second question is which version of Zorin are you using e.g. Core, Lite etc. In the meantime you may find something in here which may help:
Also are your USB ports USB2 or USB3?
