Can anyone advise me how to uninstall VirtualBox? When I check in Software there is a tick in the installed box, so I click on VirtualBox and then in the next screen I click on Remove. All I get is an error message, see the screenshot:
Can you try typing the command below into your Terminal Ctrl + Alt + T:
sudo apt-get remove virtualbox
I would also advise you to install Synaptic Package Manager instead of using the Gnome Store.
To install Synaptic Package Manager, type the command in yout Terminal Ctrl + Alt + T:
Well, if I were a Linux user of even simple understanding I might take you up on that. Unfortunately I am a clean faced Linux newbie so none of what you have said means much to me and I am very reluctant to start installing things which I know nothing at all about. I appreciate the suggestion but I'm just not close to that stage yet.
Should he fix the installation? Will sudo apt-get --fix-broken install fix the installation? If it fixes the package, then uninstall with sudo apt remove virtualbox?
Which is what I got, in a different screen pop up, after I ran the Software Updater and it updated VirtualBox. Which I though was fair enough as the stuff in Software Updater is approved by Zorin, right?
But I'm not going to allow anything like third party drivers and UEFI Secure Boot in the same sentence at this stage of my two week old Linux experience. Too scary without knowing what's going on.
How do I get out of this UEFI Secure Boot message without accepting 'OK'?
Now I see the problem.
While it is possible to use Secure boot for Linux installation, it is not recommended. Especially if you are beginner, it is better to disable it.
I have been using Linux over 10 years without secure boot and never experienced any security related issue.
I think other members of the forum @Aravisian@Storm@tomscharbach can also attest my statement.
I haven't used it. I just ran the Software Updater, as I do every time I log in, and it suggested the update, so I ran it and then got the UEFI Secure Boot message you can see in my previous post. I couldn't find a way to get out of that so I simply rebooted.
I would prefer not to, it's a dual boot setup with Win10. I'd really like to get rid of VirtualBox as it's only after I updated it that this problem arose.
