so i was installing waydroid on my zorin os core sucessfully but after i do waydroid show-full-ui its just says starting session and clipboard error, nothing else, no window showed up.. after some research its seems an hardware issue, anyone knows how to fix this?
doing waydroid log resolve this log:
(003399) [07:53:34] % /usr/lib/waydroid/data/scripts/waydroid-net.sh stop
vnic is waydroid0
/usr/lib/waydroid/data/scripts/waydroid-net.sh: 255: kill: No such process
(003399) [07:53:34] % systemctl is-enabled -q nfcd
Failed to get unit file state for nfcd.service: No such file or directory
(003399) [07:53:35] % umount /var/lib/waydroid/rootfs/vendor/waydroid.prop
(000594) [07:54:25] % lxc-info -P /var/lib/waydroid/lxc -n waydroid -sH
STOPPED
(000594) [07:54:25] % modprobe binder_linux devices="anbox-binder,anbox-vndbinder,anbox-hwbinder"
(000594) [07:54:26] % mkdir -p /dev/binderfs
(000594) [07:54:26] % mount -t binder binder /dev/binderfs
(000594) [07:54:26] % ln -s /dev/binderfs/features /dev/binderfs/anbox-hwbinder /dev/binderfs/anbox-vndbinder /dev/binderfs/anbox-binder /dev/binderfs/binder-control /dev/
(000594) [07:54:26] % modprobe -q ashmem_linux
(000594) [07:54:26] % chmod 666 -R /dev/anbox-binder
(000594) [07:54:26] % chmod 666 -R /dev/anbox-vndbinder
(000594) [07:54:26] % chmod 666 -R /dev/anbox-hwbinder
(003098) [07:55:45] Starting waydroid session
(000594) [07:55:45] % /usr/lib/waydroid/data/scripts/waydroid-net.sh start
vnic is waydroid0
(000594) [07:55:45] % systemctl is-active -q nfcd
(000594) [07:55:45] % chmod 777 -R /dev/ashmem
(000594) [07:55:45] % chmod 777 -R /sys/kernel/debug/sync/sw_sync
(000594) [07:55:45] % chmod 777 -R /dev/dri
(000594) [07:55:45] % chmod 777 -R /dev/fb0
(000594) [07:55:45] % chmod 777 -R /dev/video1
(000594) [07:55:45] % chmod 777 -R /dev/video0
(000594) [07:55:45] % mv /var/lib/waydroid/config_session /var/lib/waydroid/lxc/waydroid
(000594) [07:55:46] % mount -o ro /usr/share/waydroid-extra/images/system.img /var/lib/waydroid/rootfs
(000594) [07:55:46] % mount -t overlay -o ro,lowerdir=/var/lib/waydroid/overlay:/var/lib/waydroid/rootfs,upperdir=/var/lib/waydroid/overlay_rw/system,workdir=/var/lib/waydroid/overlay_work/system,xino=off overlay /var/lib/waydroid/rootfs
(000594) [07:55:46] % mount -o ro /usr/share/waydroid-extra/images/vendor.img /var/lib/waydroid/rootfs/vendor
(000594) [07:55:47] % mount -t overlay -o ro,lowerdir=/var/lib/waydroid/overlay/vendor:/var/lib/waydroid/rootfs/vendor,upperdir=/var/lib/waydroid/overlay_rw/vendor,workdir=/var/lib/waydroid/overlay_work/vendor,xino=off overlay /var/lib/waydroid/rootfs/vendor
(000594) [07:55:47] % mount -o bind /var/lib/waydroid/waydroid.prop /var/lib/waydroid/rootfs/vendor/waydroid.prop
(000594) [07:55:47] Save config: /var/lib/waydroid/waydroid.cfg
(000594) [07:55:47] % lxc-start -P /var/lib/waydroid/lxc -F -n waydroid -- /init
(000594) [07:55:47] New background process: pid=3189, output=background
(000594) [07:55:47] % lxc-info -P /var/lib/waydroid/lxc -n waydroid -sH
RUNNING
(003098) [07:55:47] Failed to start Clipboard manager service, check logs
lxc-start: waydroid: conf.c: run_buffer: 321 Script exited with status 126
lxc-start: waydroid: start.c: lxc_end: 988 Failed to run lxc.hook.post-stop for container "waydroid"
(003688) [07:56:49] % tail -n 60 -F /var/lib/waydroid/waydroid.log
(003688) [07:56:49] *** output passed to waydroid stdout, not to this log ***
(008043) [08:14:36] Starting waydroid session
(008043) [08:14:38] org.freedesktop.DBus.Python.RuntimeError: Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/dbus/service.py", line 711, in _message_cb
retval = candidate_method(self, *args, **keywords)
File "/usr/lib/waydroid/tools/actions/container_manager.py", line 34, in Start
do_start(self.args, session)
File "/usr/lib/waydroid/tools/actions/container_manager.py", line 133, in do_start
raise RuntimeError("Already tracking a session")
RuntimeError: Already tracking a session(008043) [08:14:38] RuntimeError: Already tracking a session
(008049) [08:14:42] % tail -n 60 -F /var/lib/waydroid/waydroid.log
(008049) [08:14:42] *** output passed to waydroid stdout, not to this log ***
