*Workspace Indicator (already installed). Lets you scroll thru your workspaces (set cursor on it).
*Clipboard Indicator. Stores clipboard entries.
*Tiling Assistant. Bonk windows into corners.
*Weather in the Clock
*Shutdown timer. Can be set to Suspend.
I've never actually installed and only use the ones that come with Pop!_OS by default. Interestingly I don't see any option to install new extensions from here... can anyone suggest how to install them? In particular, I wanted to ask if you know or recommend of some extension that serves as an audio equalizer?
Now that is quite a difference in sizes .... Flatpak ---- 808.7 MB vs deb ---- 43.4 MB .... hate to see what it would be in a Snap package if offered ....
Shell Restarter does work on Wayland. Surprising because Alt+F2+R does not. Numlockx is also working now. Or maybe booting with Numlock on just works with Wayland now.
BTW, sometimes the light doesn't come on. You gotta check by typing numbers.
Tho it does work on Wayland, it closes all apps. I originally thought this was a big disadvantage vs X11 but it actually comes in handy when you want to close all apps on all workspaces at the end of the day. Chrome's Restore Pages thingee works so it's not that much of a disruption.
Numlockx is definitely working on Wayland but the Numlock light doesn't come on. If you want it on, hit it the button twice.
BTW, using Tiling Assistant also fixes a slight Zorin bug where bonking a window on the top of the screen often doesn't work. Noticed this on more than one computer. Didn't realize how annoying it was till it was gone.
*Shell Restarter
*Shutdown Timer (set to Suspend)
*Day of week (in Taskbar settings or Tweaks)
No more Show Desktop button. It stops working if you do anything on the desktop. Easier just to scroll down to a blank desktop. Or hit the Chrome icon in the taskbar since I usually have two instances of Chrome open side by side. Set action to Toggle Windows in Taskbar settings. Workspace Indicator makes it so easy to change workspaces, there's really no reason to have windows under windows. Also keeps your taskbar from getting cluttered.
