What zorin os is best for gaming
what zorin os is best for gaming
zorin lite or zorin core?
Hi, welcome to the forum.
Can you please tell us more about your laptop/ PC, configuration, graphic card etc.
And which game do you want play.
Thanks
i have a intel i7 2600 and a gtx 780 and i have 8gb of ram and i wanna play some gta 5 and some minecraft and sometims i wanna try newer games like the avengers game
I am not a gamer ( just a casual) but I think you will be fine with both, core and lite
ow ok but does lite give more performance for gaming you think?
In my case I have better performance with Gnome (core) .
But it depends. You have better PC configuration.
You can try both, ofc, and which desktop environment you like more.
Xfce or Gnome
Zorin OS comes with gamemode pre-installed. The only thing you need to do is set up games to use it.
tested steam with valve drivers and working perfectly and smoothly without freeze or something. Here is some proof.
I can advice and temperature was max 41 temp.
