So for some reason both Xorg and Wayland randomly freeze for a few seconds for up to a minute and other rare times everything freezes (with exception my mouse for some reason but unable to interact anything with it) which forces me to shut down the machine. Now before you ask if the keyboard does not respond on those rare times.
Is there a way to fix this without doing file editing? If I have to do a few simple commands then I am find with it.
This issue existed on a different post but that got resolved
For gaming: I use Steam flathub, Heroic Launcher flathub, Sober flathub and X Minecraft Launcher flathub.
All programs. None are safe from this issue. Even on desktop doing nothing other than moving around my mouse and pressing the Windows key here and there.
FYI. Nourpon solution is to roll-back and hold that previous firmware, until a new better version is released. Nourpon has offered to notify the forum when that happens. So just have to wait for that.
Are you still having problems after following the Tutorial steps ?
With Your Hardware, maybe a newer Kernel could be a good Idea. Also, you could replace the Flatpak Versions with .deb Versions to check if it makes a Difference.
But when You now have made the Firmware Change that @Nourpon suggests, You should check first if that helps.
For sure, I'm impacted by this regression, it touch me directly and either Canonical gave me a patched linux-firmware for test (which didn't solve the problem), I would prefer to be up do date
First off, I didn't understand that it was a suggestion but more of a solution.
Second off, I am now confused. Do I change something? Do I keep it? Will I have shrodinger's computer? xD
You mean with the Firmware Package? Yes, You have changed something. With @Nourpon's Way, You have installed an older Firmware Package Version and blocked the newer Version because the new one has an Issue. That is not bad to do it.
And as @Nourpon now wrote to me, a newer Kernel wouldn't help. So, You can ignore that.
Alright so, the freeze began again today. First time was when I was looking through screenshots to learn SQL, second time I was on LibreWolf browser studying french and using Sober on the side for when I needed a bit of a break.
In both cases today, although it didnt fully freeze (because I could press the WIndows key and the Zorin Menu would pop up and allow me to guide my mouse there), it still would not let me open or close any windows or even Alt Tab to switch windows. Any application at the Taskbar would interact and I was stuck like this for the first one about... 5 minutes. As for the second one, about a minute.
Due note, I am using Xorg at this moment in time. But at least from my experience so far, I don't think there would be that much of a difference if I changed to Wayland.
